Old 08-27-2011, 05:26 PM   #16
REP
New dryer vent moisture
My best guess is that the vent dosen't go all the way to the outside vent hood,or there is a big tear in that corregated vent pipe behind the wall where it gets hot. That needs to be fixed or it will cause mold and/or wood rot.
REP is offline   Reply With Quote
Old 10-29-2011, 04:28 PM   #17
Turns out they did not tape up any of the joints at the 90 degree elbow causing air leakage in and around the bottom plate and drywall opening. Air flow is fine, this is a new home without any blockages and I verified that nothing was disconnected when I opened up the wall.
Unrelated to the actual moisture issue, someone did puncture the washer drain with a drywall screw but luckily the screw was holding the water back. They also managed to damage the black wire of the 220V plug for the dryer as well as cut out a stud to make room for the washer drain.
Gotta love the surprises in brand new homes. All fixed..
n0c7 is offline   Reply With Quote
Old 10-29-2011, 04:34 PM   #18
Average Joe/ex-Navy IC3
gregzoll's Avatar
That is why I always double check and take time doing something. No need to rush. At least you hopefully got a lot of problems nipped in the bud, and there are no others to be found. Keep your fingers crossed.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
Old 10-29-2011, 04:40 PM   #19
You really should get rid of that flex hose and run solid 4" metal pipe.
Too many lint traps.
COLDIRON is offline   Reply With Quote
Old 10-29-2011, 06:47 PM   #20
I'm on the fence about the flex hoses. A solid pipe gives people false piece of mind and the assume they do not need to clean it out(not to mention difficult to connect in tight spaces) compared to someone who regularly cleans the flex out every year or two. 90 degree elbows still trap plenty of lint regardless of hose type.
Old 10-29-2011, 06:51 PM   #21
Chicago, IL
Michael Thomas's Avatar
Originally Posted by COLDIRON View Post
Turn the dryer on let it heat up go outside and make sure your vent is blowing hot air and the right volume. Your pipe might go in the wall and disconnected inside.
Look for something like this:
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs
Michael Thomas is offline   Reply With Quote
Old 10-29-2011, 07:00 PM   #22
Checked for that outside, thanks!
Old 10-30-2011, 06:53 AM   #23
See that vent the guy is holding in Michaels picture that is wrong, that end that is showing should not be crimped it should be rounded and the piece in the house going to the out side should slide into that. Someone hand crimped that to make it fit. When you install dryer pipe you always install it in the direction of air flow from the dryer to the outside all the way from the connection on the dryer. That way no lint traps, well I can't say no lint but very little. And never use screws because they catch lint.
If you're on the fence you shouldn't be there are no false positives here it's fact no matter what material people use they should check their dryer once in a while. Just like anything else, oil, furnace filter, lint filter, air pressure in tires false positives no laziness and incompetence yes.
NOTE: No flex on dryer lines, buy a pair of tin snipes and a roll of metal tape.
Old 10-30-2011, 06:02 PM   #24
Chicago, IL
See that vent the guy is holding in Michaels picture that is wrong... .
COLDIRON is correct, per the IRC dryer vents must be installed wither with their joints running in the direction of air flow (the upstream section insert into the downstream) section, the correct part looks like this:
However, that the vent termination is not a field modification, it was manufactured that way:
and the fact that installing it would be both a code violation and a safety hazard does not stop major home improvement centers from selling them.
Cutting through sill for dryer vent mjkpainting Building & Construction 13 06-05-2012 06:14 PM
Dryer vent problem carguy4sp General Discussion 7 11-29-2010 09:26 AM
Dryer Vent DoubleHumbucker Appliances 3 10-02-2009 02:50 PM
very clogged dryer vent. Not just lint catman Tools 4 04-20-2009 05:48 PM
Building code violation fetzo Building & Construction 18 03-22-2008 03:42 PM
