New Control Unit, But AC Still Not Working - HVAC - DIY Chatroom Home Improvement Forum
Old 06-23-2010, 07:41 PM   #1
New control unit, but AC still not working
After a nasty storm over the weekend, our AC would no longer kick on and neither would the blower. I bought a new White Rodgers 50A55-843 control unit and installed it today. All went well except one ugly part. I accidentally connected the Line-H to the EAC-H terminal. The blower started running right away when I flipped the power switch on the side of the furnace. When I saw that the AC compressor wasn't running, I turned things off and rechecked, then found my mistake and switched the power line coming from the cover safety switch back to the Line-H terminal.
In this position I am not getting any blower and no AC.
I checked the 24 volt transformer and the control board is not supplying power to it. Did I blow my new $100 control unit by switching up the wires? I checked the fuse as well by the way and it is ok. I don't have any status light flashing errors either.
The house is 85 degrees so until I get it figured out, I ran a separate 24 volt AC transformer to the AC contactor to get the AC unit running, and I switched the hot line back to EAC to run the blower.
Any ideas?
Thanks,
Eric (hot and sweaty in Michigan..)
AiR_GuNNeR is offline   Reply With Quote
Old 06-23-2010, 07:51 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,112
You may have damaged the board. The EAC terminal gets energized when the board energizes the fan for heating or cooling. You backfed voltage to a relay which was not supposed to happen and after that damage occured.
Old 06-23-2010, 08:51 PM   #3
An old Tradesmen
Rewards Points: 6,098
Guess you never checked to see if the thermostat was sending 24 volts to the Y and G terminal of the board.
What is the price difference between a 2.5 ton unit and a 3 ton unit? Leoskee HVAC 5 06-12-2014 01:00 PM
Can't get unit to turn on need electrical help please-wiring diagram included igotshocked Electrical 33 01-30-2014 06:13 AM
Air Handler Works/Outside Unit Does Not g8tkeeper HVAC 7 08-03-2011 10:41 AM
Deck layout advice for working around AC unit atesgoral Building & Construction 0 05-21-2010 04:01 AM
Outside Condensing Unit not working Will B HVAC 3 05-07-2010 07:11 AM
