New Condenser Fan Motor Smoking??? - HVAC - DIY Chatroom Home Improvement Forum
Old 06-27-2014, 11:35 AM   #1
Question
Fan Motor locked up last night, nothing done could get it to stay running.
So we found a DIY HVAC supply today, got a new fan motor, got instructions how to wire it, did as told (brown and brown to cap / white, red, black to line)
Almost POSITIVE that its wired correctly, BUT it keeps smoking out the little screw holes where it gets screwed into the lid. WHY? Is there possible a reasonable explanation for this? Or is it wired wrong? Help!
moco1985 is offline   Reply With Quote
Old 06-27-2014, 12:01 PM   #2
Rewards Points: 6,652
Something else is causing this to happen. Or the motor is not the proper one. What are spec's on the plate for the old motor, same for the new one.
Old 06-27-2014, 12:55 PM   #3
Rewards Points: 907
Did replace the cap?
Bitters is offline   Reply With Quote
Old 06-27-2014, 01:46 PM   #4
yes, a new one came with the new fan
Old 06-27-2014, 01:52 PM   #5
HVAC Tech/Owner
Rewards Points: 604
Starts with smoking and the next thing it will be huffing refrigerant......
Technow is offline   Reply With Quote
The Following 2 Users Say Thank You to Technow For This Useful Post:
gregzoll (06-27-2014), plummen (06-27-2014)
Old 06-27-2014, 02:13 PM   #6
HVAC TECH.
KKinnaman's Avatar
The motor is wired wrong. Brown wires to run cap. black and white to line for high speed,or red and white to line for low speed.
KKinnaman is offline   Reply With Quote
The Following User Says Thank You to KKinnaman For This Useful Post:
Old 06-27-2014, 03:37 PM   #7
HVAC Tech/Owner
Rewards Points: 604
Which fan motor is it, inside or outside
The Following User Says Thank You to Technow For This Useful Post:
Old 06-27-2014, 09:02 PM   #8
Rewards Points: 582
condenser fan motor should be 240 volt....read data plate on new motor...
The Following User Says Thank You to ben's plumbing For This Useful Post:
Old 06-27-2014, 10:09 PM   #9
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
how about a picture of the wiring diagram?
Omce you've let the smoke out its hard to put it back in.
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 06-29-2014, 12:02 AM   #10
Rewards Points: 225
It sounds like you have a multi-speed motor... You cannot have both red and black wired in...its either going to be red and white, or black and white. If you have both red and black wired in your going to burn out your motor. The red wire is for one speed and the black wire is for another speed... Figure out which one you need.
a.man1302 is offline   Reply With Quote
Old 06-29-2014, 06:30 AM   #11
Rewards Points: 1,192
Title of topic is New Condenser fan motor smoking ??? ".
bobelectric is offline   Reply With Quote
Old 06-29-2014, 06:54 AM   #12
HVAC Tech/Owner
Rewards Points: 604
I don't recall ever seeing a 3 speed condenser fan motor.
Old 06-29-2014, 07:00 AM   #13
An old Tradesmen
Rewards Points: 8,184
Its a rescue or other such universal motor. Black used with 1 of 2 different caps is X and Y HP, Red used with 1 of 2 different caps is 2 other possible horse powers. The white is the common wire.
I carry those type of universal motors on my truck.
The Following User Says Thank You to beenthere For This Useful Post:
ben's plumbing (06-29-2014)
Old 06-29-2014, 07:05 AM   #14
HVAC Tech/Owner
Rewards Points: 604
Thanks, I don't use those, I just match up whats there.
Old 06-29-2014, 07:09 AM   #15
An old Tradesmen
Using them allows you to go from carrying 9 or more motors, to just 4 or 5, and covering a majority of what you run into.
You might want to look into them.
Tags
condenser fan motor , fan motor smoke , hvac
Wiring new A/C condenser gbishop20012001 HVAC 10 05-12-2013 08:59 PM
Any Issues: Old Condenser - New System? JulieMor HVAC 3 07-05-2012 07:57 PM
Carrier Condenser Unit Screwed? gimmes name HVAC 6 07-24-2011 07:05 AM
Goodman Fan Condenser Replacement Help bigjohnstud4200 HVAC 2 07-03-2010 01:54 PM
Condenser Fan Quits After approx 10 min kdogg HVAC 5 08-06-2008 06:03 PM
