New Condenser Fan Motor Runs Slowly - HVAC - DIY Chatroom Home Improvement Forum
Old 02-12-2012, 05:38 PM   #1
Unhappy
New condenser fan motor runs slowly
I just replaced the condenser fan motor and capacitor (orig AO Smith F48P99A76, new Diversitech WG840204 - same specs) in my Goodman outside unit. The original fan stopped turning, had high resistance between leads (700 - 1300 ohms), hard to turn by hand. The orig fan had 3 leads, one to the control board, one to the contactor, one to the cap 'fan' terminal (dual cap). The new fan had an extra lead going to the cap which I connected to the 'com' on the capacitor.
When I turned the unit on to test, the fan seems to run slowly, not 825 rpm. I measured 220 VAC between the motor's wires at the contactor and the circuit board. I don't have an ammeter.
Could you please suggest how to determine the problem?
Thank you!
ptmuller is offline   Reply With Quote
Old 02-12-2012, 05:46 PM   #2
An old Tradesmen
Rewards Points: 6,516
The brown wire with a white strip doesn't get used, if you wired to a dual run cap.
The Following User Says Thank You to beenthere For This Useful Post:
ptmuller (02-12-2012)
Old 02-12-2012, 05:57 PM   #3
Thank you soooooooo much!!! That did the trick!!
Old 09-02-2013, 10:24 PM   #4
Thank you!
Hi - interested in how you found that condenser fan motor (WG840204), as I need to replace an F48P99A76 on my goodman as well. Were you familiar with pexsupply and just did a search on the specs? It's a great find, less than 1/2 price of the A.O. unit.
Which cap did you use with it?
Is it still running well?
Thanks!
mdostie is offline   Reply With Quote
Tags
condenser fan motor
Carrier a/c condenser fan motor still running slowly after thermostat is satisfied GetYourShineBox HVAC 18 06-14-2013 12:26 PM
Condenser fan airflow direction?? nicksab HVAC 8 09-20-2011 10:24 PM
Carrier Condenser Unit Screwed? gimmes name HVAC 6 07-24-2011 08:05 AM
Condenser fan motor spinning slowly or not at all utbigrod HVAC 1 06-08-2011 10:00 PM
Goodman Fan Condenser Replacement Help bigjohnstud4200 HVAC 2 07-03-2010 02:54 PM
