New Condenser - HVAC - DIY Chatroom Home Improvement Forum
Old 10-14-2010, 04:19 PM   #1
new condenser
I just found out that my condenser coil is leaking due to corrosion and needs to be replaced. it is an R-22 unit so in short supply. The HVAC guy told me I'd need to replace the whole system and it would be several thousand.
I got curious so I tried searching for R-22 units online and found a few. Some are not the same brand and have different SEER ratings. I'm wondering if I can get one of these and get it installed.
lmbgm is offline   Reply With Quote
Old 10-14-2010, 04:27 PM   #2
HVAC / Plumbing
Condenser & coil have to match.
kenmac is offline   Reply With Quote
Old 10-14-2010, 04:51 PM   #3
when you say coil, I assume you mean evaporator coil must match the condenser coil?
When you say "match" do you mean the brand must match or the SEER rating must match?
(or both)
Old 10-14-2010, 07:12 PM   #4
HVAC / Plumbing
(or both)
Brand doesn't matter. Of course I like to use a match system. You shouldn't install a 13 seer condenser on an evap coil that was set for 10 seer condenser
Old 10-14-2010, 07:50 PM   #5
An old Tradesmen
Rewards Points: 6,142
Brand matters, when your matching for SEER.
A Goodman 13 SEER condenser on a 13 SEER Carrier coil, won't be 13 SEER in many cases.
Old 10-14-2010, 08:33 PM   #6
HVAC / Plumbing
Thanks for clearing that up ben. I didn't mean to imply for him to install mis matched brands. as you described
Goodman Fan Condenser Replacement Help bigjohnstud4200 HVAC 2 07-03-2010 02:54 PM
Residential AC Unit - Can a stalled condenser fan cause other problems? bcphoto HVAC 6 04-03-2010 11:09 AM
Condenser freezing zep HVAC 2 01-30-2010 09:04 PM
Condenser Fan Quits After approx 10 min kdogg HVAC 5 08-06-2008 07:03 PM
Condenser fan motor/compressor kristeng HVAC 3 07-26-2008 12:02 PM
