New Cased Coil - Install To Furnace - PICTURES!! - HVAC - Page 3 - DIY Chatroom Home Improvement Forum
Old 11-13-2008, 08:28 AM   #31
Rewards Points: 81
I think it looks good for my first install of a furnace. I do have a lot of experience with HVAC but its on automobiles.
hartkem is offline   Reply With Quote
Old 11-13-2008, 10:25 AM   #32
Ok, look, I'm not trying to bust your efforts, but those cinder blocs are going to transmit noise and probably wear a hole in your drain pan.
The sheet metal has to be 26 gauge minimum. You should have that furnace SUSPENDED from the roof with threaded rod connected a length of squared metal stock. If you really want a quiet install add another piece of square metal stock and have it sitting on thick springs.
hvaclover is offline   Reply With Quote
Old 11-13-2008, 03:38 PM   #33
Journeyman
I can't tell for sure but it looks like the drip leg is b4 the gas cock. If so move it to the outlet side of the gas cock. Like hvaclover said 26g min. Also don't forget to insulate. Just remenber if you are going to insulate the inside of the duct you are going to lose 2in on the width and length. Be sure to compensate for a larger supply and return by 2in. Also make sure you put canvas connectors on the suply and return. If you chose to leave the blocks in place (not recomended)(see hvaclover's recomendation)at least put isolation pads between the block and furnace.
pipefitter636 is offline   Reply With Quote
Old 11-13-2008, 04:15 PM   #34
Journeyman
hvaclover
Sorry I couldn't reply to your message says I need 20 posts. But I know what you mean
Old 11-15-2008, 05:49 PM   #35
Rewards Points: 81
I understand you are concerned about the cinder blocks making noise but what you can't see is that the drain pan is sitting on top of a 3/4 in piece of plywood which is sitting on top a 2 inch thick piece of foam insulation to dampen the noise. I also put 1/4 thick isolation pads on top of the cinder blocks between the blocks and the furnace.
Old 11-15-2008, 06:28 PM   #36
Rewards Points: 260
Is there a reason why you need the furnace raised so high? Normally, one would use pressure treated wood in the pan (4x4 or two 2x4's nailed together) with isolator pads between the furnace and wood. In your case, I would cut them the entire length of the furnace and coil and run them parallel to the unit. I would then use 8 isolator pads. Put a pad at each corner of the furnace and at each corner of the coil.
For added stability, you can use 3 pieces of wood.
1. 4x4 cut the entire length of the furnace and coil
2. 4x4 cut the length of the furnace
3. 4x4 cut the length of the coil
Piece number one is used as the back support. You will then stagger piece two and three as the front support. The only reason you do this is because the furnace is deeper than the coil.
bluefitness is offline   Reply With Quote
Old 11-15-2008, 07:09 PM   #37
Rewards Points: 260
When you move the drip leg after the shut off valve, connect your flex line to the top of the drip leg.
Old 11-15-2008, 09:06 PM   #38
Rewards Points: 81
Thanks for showing me how to hook up the drip leg.
The install manual says the furnace needs to be off the ground a minimum of 6 inches. This is because the trap for the condensate drain must be moved from inside the furnace to the bottom when used in a horizontal configuration
Old 11-16-2008, 08:48 AM   #39
Rewards Points: 260
I would still take the blocks out. It will wear a hole through the pan. There are a lot of ways to get that clearance. I think a few people have mentioned it.
Old 11-18-2008, 02:45 AM   #40
Originally Posted by lyjg1117 View Post
HN-A843微机微机继电保护测试仪       1  1、七个通道同时输出,即同时输出不同频率、相位的三路电压及三路电流、一路3U0,电压0-120V,电流0-40A/三相。2、微机继电保护测试仪 采用8.4寸TFT(800*600)真彩液晶显示屏,可依据现场采光环境设置界面颜色,提供直观图象显示 ,便于观测。3、下位机采用精简稳定的Windows ce嵌入式操作系统,Windows界面操作风格,应用程序简小,运行速度快,系统稳定,界面风格友好快捷 。4.率先在业界采用快捷键方式操作实验,全一体化设计,主机内置鼠标,键盘,也可外接鼠标跟键盘,更加方 便用户的使用习惯.1、微机继电保护测试仪 电流源 3、微机继电保护测试仪 频率   A型:直流幅值0-30A/相 0-90A/三相并联 范围0-1000Hz 分辨率0.001Hz(工频) 0.1Hz(1KHz)   交流幅值0-30A/相 0-90A/三相并联 4、相位   功率:300VA/相 范围0-360度 分辨率0.1度 精度0.1度   B型:直流幅值0-40A/相 0-120A/三相并联 5、开关量输入   交流幅值0-40A/相 0-120A/三相并联 7对空接点或电位翻转(5-250VDC)   功率:400VA/相 6、开关量输出   精度:0.2%,响应时间
ok i give up what the hell is that
kennzz05 is offline   Reply With Quote
Installing a new Furnace, Shoud I install an A/C Coil Now? hartkem HVAC 1 11-10-2008 10:31 AM
Furnace install in attic - Duct configuration hartkem HVAC 6 11-08-2008 06:46 PM
First Furnace Install - Need Some Help Getting Started hartkem HVAC 17 10-11-2008 12:55 PM
installing new rheem furnace to old a coil rad488 HVAC 1 10-17-2007 09:07 PM
Replace furnace, coil and duct system sps123 HVAC 2 01-07-2006 11:56 AM
