Old 08-11-2009, 07:06 PM   #1
new carrier heat pump furnace wont cool home
New unit constantly runs. Had service out to check things. $170.00 later found nothing wrong! The products from carrier are both the top of the line furnace and heat pump. New filter. Outside temp 90 degrees and the temp never below 75 or 76. Units run constantly. I cant believe this is normal. frustrated on the amt of money i spent for this efficiency. electric bill 100.00 more this month. outrageous... any info would be helpful.
wisjr is offline   Reply With Quote
Old 08-11-2009, 07:24 PM   #2
Is the thermostat located upstairs?
handy man88 is offline   Reply With Quote
Old 08-11-2009, 07:46 PM   #3
ranch style home. thermostat is in hall way just off the living room.
Old 08-11-2009, 08:17 PM   #4
Where is the condensate going? Can you see that there is condensate leaving the unit?
brianr0131 is offline   Reply With Quote
Old 08-11-2009, 08:53 PM   #5
HVAC / Plumbing
if it's new .. Why do they charge you to come out ??They should have given you a 1 yr. warranty after a new install. I do
kenmac is offline   Reply With Quote
Old 08-11-2009, 10:04 PM   #6
You might want to consider getting an attic fan.
Old 08-11-2009, 10:14 PM   #7
30 year tech
hvac122's Avatar
I would stay away from this idea unless you seal your attic floor.
hvac122 is offline   Reply With Quote
Old 08-12-2009, 06:38 AM   #8
I have pvc pipe out of furnace and this drains water. Also I notice condensation under heat pump on the cement slab. Could it be I need to clean vents? What about not enough insulation in the attic? Thanks for your reply.
Old 08-12-2009, 01:23 PM   #9
Is it possible the unit is under-sized for your home? Did they do a Manual J calculation to determine the size of your unit? Improper installation? Enough returns? Why is this not under warranty?
bob22 is offline   Reply With Quote
Tags
always running, wont cool
carrier infinity 50Xt packaged heat pump with infinity thermostat mguillen HVAC 12 12-05-2011 02:42 PM
Please answer this question about my Carrier Heat Pump... jifmom HVAC 4 02-20-2009 12:38 PM
Heat Pump + Aux Heat Problem - Can You Help? whitedavidp HVAC 17 12-25-2008 07:37 PM
Testing FuelMaster 21 Module? Heat Pump no Run. thehotrod11 HVAC 3 12-29-2007 03:11 PM
