-   -   new carrier heat pump furnace wont cool home (http://www.diychatroom.com/f17/new-carrier-heat-pump-furnace-wont-cool-home-50722/)
wisjr 08-11-2009 06:06 PM
New unit constantly runs. Had service out to check things. $170.00 later found nothing wrong! The products from carrier are both the top of the line furnace and heat pump. New filter. Outside temp 90 degrees and the temp never below 75 or 76. Units run constantly. I cant believe this is normal. frustrated on the amt of money i spent for this efficiency. electric bill 100.00 more this month. outrageous... any info would be helpful.
handy man88 08-11-2009 06:24 PM
Is the thermostat located upstairs?
wisjr 08-11-2009 06:46 PM
ranch style home. thermostat is in hall way just off the living room.
brianr0131 08-11-2009 07:17 PM
Where is the condensate going? Can you see that there is condensate leaving the unit?
kenmac 08-11-2009 07:53 PM
if it's new .. Why do they charge you to come out ??They should have given you a 1 yr. warranty after a new install. I do
handy man88 08-11-2009 09:04 PM
You might want to consider getting an attic fan.
hvac122 08-11-2009 09:14 PM
I would stay away from this idea unless you seal your attic floor.
wisjr 08-12-2009 05:38 AM
I have pvc pipe out of furnace and this drains water. Also I notice condensation under heat pump on the cement slab. Could it be I need to clean vents? What about not enough insulation in the attic? Thanks for your reply.
bob22 08-12-2009 12:23 PM
Is it possible the unit is under-sized for your home? Did they do a Manual J calculation to determine the size of your unit? Improper installation? Enough returns? Why is this not under warranty?
