New A/C Unit Won't Cool In Hot Temps - HVAC - Page 3 - DIY Chatroom Home Improvement Forum
Old 06-28-2012, 01:10 PM   #31
72 & 68 were most of them..
Newhome1 is offline   Reply With Quote
Old 06-28-2012, 01:32 PM   #32
Bill Kearney
Rewards Points: 1,174
Also consider that using too low a setback during the day can be a problem. AC units can only do so much, and not always as quickly as people might like.
wkearney99 is offline   Reply With Quote
Old 06-28-2012, 02:39 PM   #33
Ok thank you!!! I just got home and it's 70 in here and that's what it's set on Whaaahoooo!!!!! 106 out side!!! I was testing it!! I won't hurt it I will keep it on 72 thanks everyone for your help!! I'm going to talk to my husband about building some sort of shade for it!
Old 06-28-2012, 02:40 PM   #34
Old 06-28-2012, 04:55 PM   #35
Bill Kearney
72? Why so low? You're just wasting tremendous amounts of energy making the system work that hard. Put it at 76-78 and you'll be fine.
Old 06-28-2012, 05:19 PM   #36
Well we like it cool... 75 is kind of stuffy...
Old 06-28-2012, 05:19 PM   #37
Busy DIYer
picflight's Avatar
Rewards Points: 150
I keep mine at 79.
picflight is offline   Reply With Quote
Old 06-28-2012, 05:50 PM   #38
We know several who keep it higher and even low as 68.. 72 is pretty sufficient for us..
Old 06-28-2012, 06:49 PM   #39
Rewards Points: 6,652
I keep mine at 72 during the day, during the peak of the Summer, and 69 at night. Of course, I do not have a high gain, since I placed UV film on my windows.
My house has no insulation in the walls, but insulated in the attic with good venting, along with air leaks sealed.
The temp does not get to 73.5, until around 2-2:30 in the afternoon. It stays around 71, until around 11, then starts creeping up towards 73 by 3 or so.
So in reality, I am spending no more, but actually les, if I had it set higher. Plus I like to keep my electronics cool, along with our dog.
Old 06-28-2012, 08:51 PM   #40
That's what we do as well!! Sounds like our house has some things in common
And Ohhh how it feels good right now!! Thanks you guys for all of your help!!!
can I swap a (3) 60watt unit into a spot where I have a (1) 60watt unit? joeyboy Electrical 11 07-29-2007 07:25 PM
Heat Pump/AC not cooling, new home eshipler HVAC 7 07-25-2007 08:52 PM
new 3 ton hvac Payne units. No cool air comes out when fan, compressor,thermostat run runbikeengr HVAC 10 04-10-2007 05:59 PM
central air unit question princessme HVAC 4 07-08-2006 09:13 PM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 10:27 PM
