New A/C Unit Won't Cool In Hot Temps - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-26-2012, 06:59 PM   #16
They are comming tmrw to look at A/C..I will get out my iPad and show them all of this so maybe they will have a clue where to start..
Newhome1 is offline   Reply With Quote
Old 06-26-2012, 07:04 PM   #17
biggles's Avatar
go out and grab the LL raw copper line out on the condenser warm to hot? what the ambient days temp is,and is the condenser blowing heat into your face.if the unit cools anytime during the day and makes the setpoint it's the charge that isn't right..need a split on the the air handler not the registers.then are all your supply and return ducts sealed with mastic or duck tape...straight runs or flex duct all looped around...pix if possible
Old 06-26-2012, 07:28 PM   #18
Ok so I called my husband and he told me to go see if the unit is running outside! It's not!!! He said to turn it off inside!! It's been running all day just the fan I guess??? What could be the problem?? Ac burnt out??
Old 06-26-2012, 11:06 PM   #19
blown fuse
hvac5646 is offline   Reply With Quote
Old 06-26-2012, 11:08 PM   #20
To the OP...with out subcooling and superheat readings we can only guess...
but I'm betting you have a partial restriction.
Old 06-26-2012, 11:15 PM   #21
I'm Your Huckleberry
Rewards Points: 2,270
Originally Posted by hvac5646 View Post
blown fuse
If it were a blown fuse than there'd be no controlling the inside and that is working via the stat in cooling mode or at least that's what I'm led to believe. Stat is on cool, inside is on but not the condenser.
It's going to be a pressure switch, compressor thermal overload, breaker, float switch, something specific to the condenser.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 06-27-2012, 10:51 AM   #22
Ok so, heat and air guy is here, pressure switch when off, he claims when he put freon in the unit he got air in it and that's why it had not been properly cooling.. He is draining and putting more freon in now.. ??? He said that will fix the problem..
Old 06-27-2012, 06:16 PM   #23
a/c guy was here earlier and left, he said all problems was because of the issue I said before.. He fixed it, so I put my a/c on 69 left for 6 hours and it won't get cooler than 75 in here.. Some say that's normal, I've never lived somewhere that you put the thermostat on something and it stays 5-7 degrees hotter! No matter where I lived..
Old 06-27-2012, 07:08 PM   #24
Bill Kearney
Rewards Points: 1,174
Just how hot/humid is it in your area? An AC unit can move the temp only so far based on outside temperature.
wkearney99 is offline   Reply With Quote
Old 06-27-2012, 07:17 PM   #25
107 Oklahoma.. Very humid..
Old 06-27-2012, 08:25 PM   #26
Rewards Points: 77
Is maintaining 75 inside when it's 107 and humid outside an improvement over the performance pre-service? In any case, it doesn't sound so bad to me...
tima2381 is offline   Reply With Quote
Old 06-27-2012, 09:40 PM   #27
It's not bad I just lived in cooler/more comfortable places in same town, kind of disappointing since this is my first brand new home and I get hot when I get ready! But you are right it isn't so bad..
Old 06-28-2012, 12:12 AM   #28
Rewards Points: 77
Others things to consider are shade tree coverage, insulation differences, etc. If there are any comparable houses around you, ask your neighbors how they're doing, but to get a meaningful answer, you'll probably have to measure temps yourself and wait until you know the system's been running an hour or two.
Old 06-28-2012, 08:04 AM   #29
The houses right next to us just built as well, no problem with theirs, and it matches what they set it on.. Shade trees are a good idea..
Old 06-28-2012, 12:43 PM   #30
Rewards Points: 77
What do they set it on?
can I swap a (3) 60watt unit into a spot where I have a (1) 60watt unit? joeyboy Electrical 11 07-29-2007 07:25 PM
Heat Pump/AC not cooling, new home eshipler HVAC 7 07-25-2007 08:52 PM
new 3 ton hvac Payne units. No cool air comes out when fan, compressor,thermostat run runbikeengr HVAC 10 04-10-2007 05:59 PM
central air unit question princessme HVAC 4 07-08-2006 09:13 PM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 10:27 PM
