New A/C Or Better Insulation? - HVAC - DIY Chatroom Home Improvement Forum
Old 12-01-2008, 10:53 PM   #1
New A/C or better insulation?
I have a two story 1300 sq ft duplex. The 2.5 ton central A/C has a heat pump and eats about 3 kwH of electricity when it is heating.
It takes 1 hr 7 min for it to heat the air temperature 2 degrees F and 39 min for the temperature to drop 2 degrees.
Does this sound normal?
The temperature outside is in the low 30s and inside the thermostat is set to 71 F.
Do you think I need a more powerful A/C or should I improve the insulation? I feel slight cold air coming in on the sides of the two exterior doors (front and back). I will try to add more door seal material along the sides but they may only make a small difference. The doors themselves are cheaply made (thin hollow type). I'm thinking I could invest in a thicker door or double door. The windows are okay; double pane but installed in 1983 so not the best quality.
Or is my heating simply not powerful enough.
grgryl is offline   Reply With Quote
Old 12-01-2008, 11:51 PM   #2
An old Tradesmen
Rewards Points: 7,802
Seal the doors, that will make a big difference.
May want to recheck around your windows for air leaks, if you find any, caulk them.
When is the last time your heat pump was cleaned and serviced.
Might need a good cleaning.
Old 12-02-2008, 12:10 PM   #3
sweaty
Rewards Points: 276
The attic is always a big leak. Seal penetrations from wires, pipes, and the hatch. To keep the top floor cool in the summer, put in a radiant heat barrier. Finally, blow in a thick layer of insulation above your existing insulation.
sweaty is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Old home insulation woes nowwhatnapster Building & Construction 15 11-02-2008 11:59 PM
Insulation over Attic Walkway BigJimmy Building & Construction 4 06-23-2008 02:13 AM
attic insulation question dderolph Building & Construction 10 11-03-2007 05:21 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 08:33 PM
