Old 09-06-2007, 12:57 PM   #1
dan
Default New Buderus installation
Hi
We are finally replacing our original 50 year old oil boiler with a new G115/34 Buderus. The installer, however did not recommend installing the smart logamatic controller unit and said it is very expansive (another 1000$ or so, installation on top of the full system including circulator etc @ 5400$) and most importantly is not reliable !!!
Is he right, or is it just too complicated for them?
Should we insist on the controller (we are willing to pay).
Dan
dan is offline   Reply With Quote
Old 09-06-2007, 10:55 PM   #2
In way over my head.
Clutchcargo's Avatar
I don't know how much benefit you'll get with the controller given that this is an oil burning unit. It makes more sense with a gas mod/con boiler where you can run lower temperatures. With oil, I believe, the lowest you can run is 130-135F before it starts sooting.
You'll never be sorry you bought the best.
Clutchcargo is offline   Reply With Quote
More On This Topic
Depending on where you live in the United States, you may encounter high monthly bills for heating your home. Many homes in warmer climates are built with wide windows and open floor plans, so unexpected low temperatures often result in cold, drafty... Read More »
Welcome to Expert Village my name is Dr. Ed Riffel. In this clip we're going to do some intermittent stretching. It's also referred to as brachiation because it opens up the ribs, the intercostals spaces, allowing for more expansion of the lungs. We're... Read More »
Learn about Controlling the Door in Heroscape Expansion sets in this free wargaming instructional video from our Hero Scape expert and gaming authority. Read More »
When you're trying to save money each month in energy costs, one of the first and best places to make a change is in the hot water system of your home. Homeowners can end up spending hundreds of dollars more per year than they should as a result of an... Read More »
Hi there! This is Daniel on behalf of Expert Village. In this series of clips we are going to be installing a Power Bolt 1000. It's made by Wiser and Quickset Bolt. You can find them at your local hardware store. They are very easy to install. We are... Read More »
Alside Sliding Door Installation sandyman720 Building & Construction 5 08-27-2007 02:50 PM
Sump pump installation moggi1964 Plumbing 9 04-25-2007 10:28 PM
Improper Installation of Steel Composite Tub House_Amuck Plumbing 1 03-19-2007 05:50 PM
Aluminum Soffit and Fascia Installation... MoparAutoworks Building & Construction 1 12-17-2006 09:46 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
