New Bryant Heat Pump With Carrier Air Handler - HVAC - DIY Chatroom Home Improvement Forum
Old 09-12-2012, 07:38 AM   #1
New Bryant Heat Pump with Carrier Air Handler
I just had a new Bryant heat pump installed with a new Carrier air handler. The contractor said that it didn't matter that the units were different brands since the air handler matched the output from the heat pump. I've heard that these units must match in order to have a properly working system. Is that true or will they work together properly?
Greg0145 is offline   Reply With Quote
Old 09-12-2012, 09:57 AM   #2
Carrier and Bryant are the same company. Just as long as the specs are matched up you're good to go.
hvac benny is offline   Reply With Quote
The Following User Says Thank You to hvac benny For This Useful Post:
Greg0145 (09-12-2012)
Old 09-12-2012, 10:31 AM   #3
I'm Your Huckleberry
Rewards Points: 2,270
Yes, Carrier is the parent company of Bryant and Payne.
American Standard and Trane, same company.
Lennox and Aire-Flo, the same.
Ford Lincoln Mercury, Jeep Chrysler Dodge, etc..
Thanks.
Doc Holliday is offline   Reply With Quote
VisionPRO Setup Functions & Heat Pump infoskr HVAC 43 07-12-2015 04:28 PM
gas furnace efficiency, hybrid heat pump, and payback times av-geek HVAC 1 06-22-2012 07:46 AM
carrier air handler / heat pump electrical requirements Cysnake Electrical 6 05-18-2012 10:43 AM
Help with a carrier 50 HX heat pump to tstat bmata12 HVAC 1 03-16-2012 09:08 PM
Heat Pump will not cut off sunliner HVAC 13 05-17-2011 05:38 AM
