New Bryant Gas Furnace - Fuse Keeps Blowing - HVAC - DIY Chatroom Home Improvement Forum
Old 01-08-2012, 04:02 PM   #1
I have a Bryant Gas Furnace (Model 310AAV) that is less than a year old. There was a problem with the furnace not coming on and it was discovered that the 3 amp fuse on the control board was blown. A new fuse was installed, the furnace fired up, heat came on and ran for about 10 minutes, then the furnace shut off again. The new fuse had blown out. Installed new fuse #2 and, when the blower door was put back on, the fuse blew again. Had one more new fuse #3, installed it, manually pressed the blower door safety switch, there was a visible flash at the switch and fuse #3 was blown.
In a matter of 30 minutes, 3 new fuses were blown so still no heat. Is it possible that the blower door safety switch has gone bad so, when triggered, it blows the fuse? Can I, or should I, try a 5 amp fuse to see if that makes a difference?
If anyone has any thoughts they'd be appreciated.
DIYerIT is offline   Reply With Quote
Old 01-08-2012, 04:06 PM   #2
you have a low voltage short........call the company that installed it and get them out right away.
harleyrider is offline   Reply With Quote
The Following User Says Thank You to harleyrider For This Useful Post:
DIYerIT (01-08-2012)
Old 01-08-2012, 04:22 PM   #3
Thank you harleyrider, I appreciate the fast response and advice. I'll give the installer a call.
Tags
bryant , furnace , fuse , gas
Bryant 355MAV furnace and A/C blower not starting rajar2 HVAC 39 11-05-2015 01:03 PM
Natural Gas Cost For Furnace 1 Hour Run Time hammerlane HVAC 25 01-14-2015 02:13 PM
16-year old Bryant Plus-90 furnace phillip9 HVAC 5 03-05-2013 01:11 PM
New AC & Furnace not blowing enough air dficken HVAC 13 07-28-2011 06:21 PM
Bryant +80 Gas Furnace won't light tr0910 HVAC 4 01-14-2009 07:11 AM
