New Boiler (maybe) - HVAC - Page 3 - DIY Chatroom Home Improvement Forum
Old 11-29-2010, 05:05 PM   #31
Just call me Andrew
Rewards Points: 1,020
Oh, if I get a new boiler, it'll be a 93% gas, not oil. I already have gas run to the side of the house.
Andrew
secutanudu is offline   Reply With Quote
Old 11-29-2010, 05:05 PM   #32
An old Tradesmen
Rewards Points: 8,176
There is either a part, or a setting that isn't right on your oil burner. its not the boiler itself.
You need a good oil tech.
Old 11-29-2010, 05:22 PM   #33
Hvac Pro
yuri's Avatar
Rewards Points: 396
I wonder how a person can figure out the ACTUAL cost difference to burn oil vs gas in a boiler. Doesn't oil have a higher thermal value. Guess it would depend on the efficiency of the burner and design of the boiler. I would investigate the price of a new burner. Then again it has to be setup properly and if his techs are not so good that may not work too well either. My plumbers prefer and sell a lot of the 80-85% Weil McLains. Condensing boilers have to get the system flushed PERFECTLY or they get pumps cavitating and popcorn noises in the boiler/pipes if there is any residue/cutting oil or other coatings in the system as they run a LOT hotter than the mid efficiency units. LOTS to think about.
Old 11-29-2010, 05:32 PM   #34
An old Tradesmen
For cost comparison. You simply convert all the fuels to therms of heat. And then compare the cost per therm.
Old 11-29-2010, 05:48 PM   #35
Hvac Pro
yuri's Avatar
Rewards Points: 396
Depending on how much gas costs per therm. oil may not be that much more expensive. A new burner should go for at least 5 yrs with no problems. May have a bad oil pump with a bad gear piling up intermittently. If the oil tank is buried outside I would go gas and eliminate that problem before it happens (leaks) EPA issues.
Old 11-29-2010, 05:54 PM   #36
An old Tradesmen
Could be the burner motor has a dead spot in the start winding. With a dead spot in the start winding. they won't trip their thermal over load. And they usually move off the dead stop when the safety trips. So it starts fine when you push the reset button.
Old 11-29-2010, 05:56 PM   #37
Hvac Pro
yuri's Avatar
Rewards Points: 396
The new burner sounds better all the time. 5 yrs smooth sailing other than a new nozzle each yr.
Old 11-29-2010, 06:48 PM   #38
Just call me Andrew
Any ballpark on how much a new burner would cost?
Andrew
Old 11-29-2010, 07:28 PM   #39
An old Tradesmen
Varies too much from area to area. And which burner you get.
But its a whole lot less then a new boiler with a new burner.
Old 12-01-2010, 05:24 PM   #40
Just call me Andrew
I am leaning towards a new gas boiler. I really do not want to put any more money into this thing.
The HVAC contractor I want to use is suggesting a Triangle Tube Prestige 95% boiler. It's the same price as the Weil-McLain. Any thoughts on this brand?
Andrew
Old 12-01-2010, 05:29 PM   #41
An old Tradesmen
I like Weil Mclain Ultra.
TT's ok.
Indoor Boiler Question AndrewF HVAC 134 05-13-2011 05:15 PM
I Need a New Boiler. What do i need to know New Boiler Co Plumbing 0 10-23-2010 06:03 PM
Burnham boiler banging/thumping noises quadradeuce HVAC 6 10-02-2010 09:55 PM
Oversized boiler solution (radiant heat)? gbwillner HVAC 5 02-14-2010 06:28 PM
Boiler w. Hydronic Air & Honeywell Aquastat DanA28 HVAC 1 01-08-2009 04:21 PM
