New Boiler (maybe) - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-22-2010, 03:32 PM   #16
An old Tradesmen
Rewards Points: 7,332
Some burners can't be down fired that low. The retention head must be changed on others to down fire that low.
Good chance it has too much combustion air.
Did he use a combustion analyzer , or at least a Fyrite kit to check to see how its burning?
Old 11-22-2010, 03:36 PM   #17
Just call me Andrew
Rewards Points: 1,020
He had a meter that made a buzzing sound, it was the one he used to check for CO. He also said it checks for excess air, he checked it in the hole in the exhaust. That's how he decided what air setting to use.
Is that a combustion analysis?
Andrew
secutanudu is offline   Reply With Quote
Old 11-22-2010, 03:44 PM   #18
An old Tradesmen
It may have been. Did he leave a print out. or write the results down on your invoice?
He should have also done a smoke test, before he used an analyzer.
Old 11-22-2010, 03:46 PM   #19
Just call me Andrew
He didn't leave me any results. He did do a smoke test, a few different times.
Andrew
Old 11-22-2010, 03:52 PM   #20
An old Tradesmen
Without knowing the results. Can't tell you much.
He could have too much excess air.
Doubt your boiler was built to be fired that low.
Old 11-22-2010, 03:53 PM   #21
Just call me Andrew
I may end up getting another company to come out and get a second opinion. The red button tripping was happening last year too...so that's not new. Two different companies and still nobody has figured it out.
Thanks for the quick and multiple responses by the way.
Andrew
Old 11-22-2010, 04:05 PM   #22
An old Tradesmen
Your welcome.
It could be many different things.
Pump
motor
transformer
bad air adjustment
weak cad cell(detects the flame)
misaligned cad cell(can't see the flame right)
Bad primary(doesn't recognize the signal from the cad cell
loose wire
improper electrode setting
Bad Z setting
And a few more things to boot.
Old 11-22-2010, 06:14 PM   #23
Hvac Pro
yuri's Avatar
Rewards Points: 2,240
Buy a gas boiler. Lot less of those problems and it burns cleaner. Stay with Weil McLain though.
Old 11-22-2010, 06:55 PM   #24
Just call me Andrew
That's the plan....when the $$ situation improves!
Andrew
Old 11-27-2010, 03:56 PM   #25
Just call me Andrew
So I came home from a few days away and my house was like 45F. Apparently the sensor tripped and shut off the boiler again. Not a huge deal, i hit the button and turned it back on for now.
Since I have to heat my house up like 25 degrees, which will take forever, can I turn up the max temp on the boiler to make it go faster? If so, how high is too high? Normally it's been set to 180. Can I go to 200? More? Less?
Thanks!
I know I may not get a response tonight, but it's good to know for next time.
Andrew
Old 11-27-2010, 04:20 PM   #26
An old Tradesmen
Best just to let it at 180.
Turning it up to 200 will heat your house faster, if the boiler is large enough to get the water temp that high. But, it can also make air in the system. which will later cause you to have no heat.
The Following User Says Thank You to beenthere For This Useful Post:
secutanudu (11-27-2010)
Old 11-29-2010, 10:57 AM   #27
Just call me Andrew
So this red button has been tripping on me a few times a day. I am at the point where I'm ready to just bite the bullet and get a new (gas) boiler. I have put too much into this one already, plus the prices of cleanings.
The pro I plan to use for this says he'll install whatever manufacturer I want. He mentioned that he never sees many problems with Weil-Mclain or Utica. Any preference between these, or something else that I haven't mentioned? What types of things should I look out for?
Andrew
Old 11-29-2010, 04:25 PM   #28
An old Tradesmen
I prefer Weil Mclain.
Hate to see a good boiler pulled because a tech can't figure out why the burner is tripping.
You know. A new burner is cheaper then a whole new boiler.
Old 11-29-2010, 04:36 PM   #29
Just call me Andrew
So maybe it's worth a 3rd opinion before I pull this one. If I do get a new one I was thinking of getting a Weil-Mclain 93% efficiency...I think my oil burner is in the low 80s. Not sure it's worth it just for that alone? Obviously I am leaning towards a new one, but maybe that's just my frustration talking...
Andrew
Old 11-29-2010, 05:03 PM   #30
An old Tradesmen
Ain't gonna get 93% efficiency from an oil burner. And have it be reliable.
An Adams condensing oil furnace is 90%plus efficient. When it works.
It also needs to be cleaned twice a year. So it actually cost more to use, then an 80% efficient furnace.
If you do decide to get a new oil boiler. Stay with an 80 to 84% efficient one. They don't require as much maintainence. As super high efficiency one.
Indoor Boiler Question AndrewF HVAC 134 05-13-2011 05:15 PM
I Need a New Boiler. What do i need to know New Boiler Co Plumbing 0 10-23-2010 06:03 PM
Burnham boiler banging/thumping noises quadradeuce HVAC 6 10-02-2010 09:55 PM
Oversized boiler solution (radiant heat)? gbwillner HVAC 5 02-14-2010 06:28 PM
Boiler w. Hydronic Air & Honeywell Aquastat DanA28 HVAC 1 01-08-2009 04:21 PM
