New Boiler Doesn't Shut Down - HVAC - DIY Chatroom Home Improvement Forum
Old 11-09-2012, 07:00 PM   #1
new boiler doesn't shut down
I just installed a dunkirk oil fired burner. Am expetiencing a problem with the pressure relief valve popping. It is set at 180 however it does not shut off at 180. Theoil pressure is over 50 psi. Can you offer some insight
gramps8 is offline   Reply With Quote
Old 11-09-2012, 08:58 PM   #2
An old Tradesmen
Rewards Points: 6,132
Oil pressure? The oil pressure should be at least 100 PSIG.
Now if you mean water pressure, that is a different story. Sounds like either the aquastat is bad, wired wrong, or set up wrong.
Pics of the wiring may help.
New Boiler for an Office - Got Two Quotes, but What Do We Need? Prolow Plumbing 0 09-17-2012 07:10 AM
Gas boiler will not shut off!! karldl HVAC 1 10-27-2011 05:59 PM
Shut off boiler for the summer? secutanudu HVAC 2 08-01-2011 12:34 PM
I Need a New Boiler. What do i need to know New Boiler Co Plumbing 0 10-23-2010 07:03 PM
Boiler Shut Down SassySue General DIY Discussions 3 01-01-2008 12:49 PM
