New Boiler - HVAC - DIY Chatroom Home Improvement Forum
Old 10-12-2008, 12:13 PM   #1
New Boiler
Does anyone have any thoughts on the pros and cons of replacing a 50 year old 144,00 btu cast iron boiler with a copper fin boiler.
globedog12 is offline   Reply With Quote
Old 10-12-2008, 12:31 PM   #2
Higher efficiency for lower energy use and smaller energy bill.
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
Old 10-12-2008, 01:34 PM   #3
What he said
hvaclover is offline   Reply With Quote
Old 10-12-2008, 02:48 PM   #4
Custom Cabinet Maker
Before you toss the boiler try changing to a new high efficiency Beckett or similar brand gun. If you had your present gun tested probably under 50% and a new closer to 85% on oil higher on gas
skymaster is offline   Reply With Quote
Old 10-12-2008, 08:53 PM   #5
tk03's Avatar
Rewards Points: 150
Get rid of that dinosour. The AFUE even with a new burner will be about 60%.The combustion efficiency may be as high as 85% but the thermal and AFUE efficiency is lost.
You can go to any new boiler and save big bucks. The most important step in replacing the boiler is to properly size it and pipe it properly.
For more information on proper sizing and FAQ on proper sizing see the website below.
www.comfort-calc.net/homepage.html
tk03 is offline   Reply With Quote
Old 10-12-2008, 09:11 PM   #6
NATURAL GAS RULES!
ASK MY WIFE. sHE SAYS i'M FULL OF IT
Old 10-12-2008, 10:14 PM   #7
TK; Man u iz pickin on those defensless dinosaurs ROFLOL . I own one :{:{ steam system no less ouch
Old 10-12-2008, 10:20 PM   #8
An old Tradesmen
Rewards Points: 8,154
Good chance his current burner is in the mid 70% SSE range.
Power gas burners are not very efficient. And if facy can cost you more to use in boilers design for a high temp in the combustion chamber.
Putting a new burner in his old boiler will save money on his heating bill, but not nearly as much as replacing it with a low mass boiler.
If his old boiler holds 30 gallons of water, and a copper fin holds 5 gallons.
His standby loss is reduced by over 70%.
A new burner can get him 82 to 85% combustion efficiency, and maybe get him a AFUE of 70% on his old boiler.
Old 10-12-2008, 11:22 PM   #9
are older boilers covered in an asbestos blanket?
unixb0y is offline   Reply With Quote
Old 10-13-2008, 07:13 AM   #10
An old Tradesmen
Some are.
Old 10-13-2008, 10:18 AM   #11
beenthere; Thanks now that is great and clear info. It made it clearer for me to understand what I did last year. I had an old Burnham V3 with updated beckett, kept it running a perfect as I could however I got a great chance and deal on a Weil Mc Lain Gold 4 section steam boiler. Way shorter cycle times to a head of steam, cut oil by about 40%. Guess it is what you called a low mass boiler. Is a wet base CI, but the way is is setup is really good, pre and post purge ect.
Old 10-18-2008, 06:10 PM   #12
man! Your quick!
Old 10-18-2008, 06:32 PM   #13
An old Tradesmen
Originally Posted by hvaclover View Post
man! Your quick!
I missed something.
Old 10-18-2008, 06:36 PM   #14
Originally Posted by beenthere View Post
I missed something.
I just killed a spammer
Ten posts and each one had a sneaker site link.
Old 10-18-2008, 08:05 PM   #15
An old Tradesmen
Ah.
I got emails he had replies to thread I posted in.
But then there was no post by him.
I thought I needed new glasses again already. LOL
Circulation pump on boiler uncleneiler Plumbing 4 06-22-2010 09:01 AM
Boiler Shut Down SassySue General DIY Discussions 3 01-01-2008 11:49 AM
How can I increase PSI in my boiler? (pics attached) drh HVAC 3 12-18-2007 05:26 PM
Boiler Options -Will Boiler be good enough??!! deano54321 Plumbing 2 10-28-2007 06:18 PM
Steam boiler corrosion problem franklopes HVAC 4 11-09-2006 08:02 PM
