New Blower Motor Blues - HVAC - DIY Chatroom Home Improvement Forum
Old 01-07-2010, 12:39 AM   #1
Question
New blower motor blues
Hello DIYers, Happy New Year!
I just replaced the blower motor in a Magic Chef G66-100D-1 forced air furnace and I think I rewired incorrectly.
The furnace would light but then shut down because of high temp, I had checked for power going to the old blower and confirmed it was being energized but it would not come on.
So I changed the blower motor, and rewired as follows.
The black line from outlet is wired to the black motor lead,
The white motor lead is connected to the blue lead from fan limit switch,
The black lead from fan limit switch is connected to door limit switch,
The door limit switch is connected to the white neutral,
The red lead from fan limit switch is connected to the black lead on transformer,
The white lead from transformer is connected to neutral.
Is this right? Probably not.
Can anyone tell me the correct wiring sequence or does anyone know where to get a diagram?
Thanks!
EduardoG is offline   Reply With Quote
Old 01-07-2010, 12:21 PM   #2
The white wire on the motor is also a neutral. no clue about the rest.
SKIP4661 is offline   Reply With Quote
Old 01-07-2010, 12:34 PM   #3
Old 01-07-2010, 07:31 PM   #4
I am happy to report that the blower blues are gone, turns out it was a faulty fan limit switch.
I traced the voltage through and determined that the fan switch was not functioning, changed it out and she fired right up.
Old 01-07-2010, 07:40 PM   #5
An old Tradesmen
Rewards Points: 7,802
So the old motor was good.
Old 01-08-2010, 06:30 AM   #6
Thought you said you checked power at the motor??
SULTINI is offline   Reply With Quote
Old 01-08-2010, 09:51 AM   #7
Here is the whole story
Replaced the motor, which was confirmed bad, rewired incorrectly, heater would not come on, spent 3-4 hours on line scouring for diagrams, calling manufacturers and HVAC houses but to no avail no one had a wiring diagram, retraced my wiring with voltage detector and determined power to fan limit switch but none out could switch also be bad, so I changed it out for a new one, which by the way had a wiring diagram in the box, installed and wahla Total cost 4 hours on line, 2 hours back and forth to parts house, 2 hours labor, $150 for new motor and fan limit switch. Cost of satisfaction of DIYing it, priceless
Old 01-08-2010, 11:56 AM   #8
An old Tradesmen
From your wiring description.
Its wired wrong.
It may be working, but its wired wrong.
Your wiring description makes it sound like you wired the whole furnace from scratch.
Or someone else blotched it up sometime earlier.
The neutral is not to be wired through a switch.
Old 01-09-2010, 12:52 PM   #9
Helle been there;
You are correct, I had crossed a couple of wires which caused it not to work, but with diagram that came with the new limit switch I was able to correct it. The safety switch is wired through the line and not the nuetral.
have a good one!
Old 01-03-2012, 01:16 AM   #10
Wiring diagram
Hi Edwardo,
Do you have the wiring diagram mentioned in the conversation above?
I have the same furnace, and am trying to hook up a new thermostat.
Would you consider mailing a copy to me for a fee? This would be a great
help. Please let me know.
Peter
pmoores is offline   Reply With Quote
Comfortmaker blower intermittent problem jh44ny HVAC 12 07-31-2011 06:41 PM
Heat comes on but blower never does aczer HVAC 12 02-13-2011 06:57 AM
Trane Furnace Blower Running Nearly Continuously stephensandlin HVAC 3 01-03-2010 01:21 AM
Carrier 58MXA Wiring Blower Switch 63012753 HVAC 0 10-06-2009 09:09 PM
AC blower short cycling-works on heat though Steve60007 HVAC 14 06-22-2009 04:00 PM
