New Blower Moter Heats Up And Shuts Down - HVAC - DIY Chatroom Home Improvement Forum
Old 05-21-2011, 09:44 AM   #1
new blower moter heats up and shuts down
I just replaced the blower motor in a Ruud air handler and it works for a short time but then heats up and shuts down. I know its not an air flow problem as Ive checked this. I also replaced the capacitor.
drplumb1 is offline   Reply With Quote
Old 05-21-2011, 09:55 AM   #2
I'm Your Huckleberry
Rewards Points: 2,270
In heating mode? In cooling mode? In fan on? What and when is it shutting down and how long is it running before it's shutting down ? Is the heat coming on in heating mode? If so, how long is the system running before turning off?
Last edited by Doc Holliday; 05-21-2011 at 09:56 AM. Reason: air handler, not flames.
Doc Holliday is offline   Reply With Quote
Old 05-21-2011, 09:59 AM   #3
See if more then one blower speed is getting powered at the same time and check the capacitor.
Old 05-21-2011, 10:29 AM   #4
biggles's Avatar
make sure the mounting bracket isn't too tight around the motor verify your speeds hi cooling lo or med lo for heating..
Old 05-21-2011, 12:44 PM   #5
blower quits in cooling mode, dont know about heating mode. blower runs for about 15 minutes before getting hot and shuting down on overload. Outdoor unit continues to run. cleaned evap. coil and squriel cage.Made sure its only running on one speed.Still same problem
Old 05-21-2011, 01:18 PM   #6
is it running in the right direction?
Old 05-21-2011, 03:37 PM   #7
Does it have the correct voltage feeding it?
Artco is offline   Reply With Quote
Old 05-21-2011, 03:54 PM   #8
Is the replacement motor the same HP as the old one??
Furnace Shuts down B4 Blower motor engages Kooks from Michigan HVAC 5 03-18-2011 12:11 PM
Electric furnance blower shuts off. mrose HVAC 11 12-21-2010 03:43 PM
Blower shuts off even when set to 'on' fetzer85 HVAC 1 07-05-2010 11:48 AM
Trane XV 90 shuts off burner and exaust blower zootjeff HVAC 0 12-01-2009 11:50 PM
blower shuts off in auto after 5 secounds Kevin MacAllister HVAC 1 02-03-2007 11:41 AM
