New Air Inducer Fan Not Working. Bryant Gas Pack. - HVAC - DIY Chatroom Home Improvement Forum
Old 10-17-2012, 09:50 PM   #1
New air inducer fan not working. Bryant gas pack.
Hi. When I turned the heat on for the first time this year, the fan wheel on the air inducer fell apart from rusting out. The unit is a Bryant gas package. I replaced the air inducer assembly which was a unit with the fan motor, fan wheel, and housing. It was identical to the part that came off. Installation went smooth, but the heater will not start. I get an error code with 6 blinks which indicates a problem with air inducer motor. I am certain I installed it correctly.
Is there a reset proceedure from when the original fan wheel fell apart and caused the system to shut down?
Any ideas? Thanks.
Slammy is offline   Reply With Quote
Old 10-17-2012, 10:27 PM   #2
Rewards Points: 610
does the ID fan motor run at all?
techpappy is offline   Reply With Quote
Old 10-17-2012, 10:39 PM   #3
No. The fan does nothing. I hear a slight vibration noise coming from the area (not fan) for maybe 30 seconds and then it stops and the error light starts blinking.
Old 10-17-2012, 11:20 PM   #4
how
Rewards Points: 1,104
I would test the power supply to the ID (with the inducer electrically disconected from the furnace) when there is a call for heat.
If the board supply is OK then you can hard wire the new inducer assy from another power source (extension cord) to test that it's OK.
how is offline   Reply With Quote
Old 10-18-2012, 06:44 AM   #5
Rewards Points: 1,296
Can you spin the fan/motor by hand when it is installed? Sounds like it may be binding on something
danpik is offline   Reply With Quote
Old 10-18-2012, 11:30 AM   #6
I had an technician friend come take a look and it was the capacitor. I guess when the motor bound up after the fan wheel imploded it killed the capacitor.
My electrical skills are weak. Otherwise that would have been an easy diagnosis for someone with basic electrician knowledge.
In any event, thanks for the replies. This is a good site. Glad i found it.
Bryant Plus 90 - No Blower Ducaticorse HVAC 13 01-03-2015 04:39 PM
Bryant Gas pack Burner problem mswirtes HVAC 6 11-09-2010 11:25 AM
Replacing Fasco 7062-3136 draft inducer blower on my Bryant Gas Furnace thalweg76 HVAC 0 02-20-2010 03:35 PM
Bad Bryant Plus 90i inducer motor/unit? PJoe HVAC 0 12-28-2009 07:17 PM
