New AC Not Cooling House - HVAC - DIY Chatroom Home Improvement Forum
Old 05-31-2011, 11:27 PM   #1
New AC not cooling house
The unit in the attic is supposed to be fairly new. The coils and the fan are clean. The unit outside was just put in less than 2 weeks ago. The thermostat was put on today. The air blowing out of the vents is in between 52-60 degrees, but the house won't get any cooler than 74 at night, 77 during the day with the thermostat set at 70. Help, I hate the heat and the landlord doesn't seem to want to pay someone who knows what they're doing.
emmismee is offline   Reply With Quote
Old 06-01-2011, 12:30 AM   #2
Turn off the t-stat. Remove red winding connection from tstat and wait 3 minutes.don't let the red wire touch anything. After 3 minutes put the red connection back. Turn the tstat back on to auto at cool that should reset the tstat after it comes on wait 5 minutes go outside and remove or take off breaker power switch to ac(not main breaker) breaker switch next to outside unit and wait 30 seconds and turn the breaker back on. Get a water hose and rinse off the coil real good that helps a lot. Touch the outside thick pipe it should be real cold and outside fan motor should be throwing hot air. If this doesn't work then it needs more freon.
dallastxtech is offline   Reply With Quote
Old 06-01-2011, 07:30 AM   #3
Since you rent and the landlord doesn't want to pay for a tech to come out the options become pay for the call yourself, buy a window AC for additional cooling or move. You don't want to play HVAC tech and DIY because then you can be blamed for any problems .
Old 06-01-2011, 08:07 AM   #4
Rewards Points: 1,520
"Turn off the t-stat. Remove red winding connection from tstat and wait 3 minutes.don't let the red wire touch anything. After 3 minutes put the red connection back. Turn the tstat back on to auto at cool that should reset the tstat after it comes on wait 5 minutes go outside and remove or take off breaker power switch to ac(not main breaker) breaker switch next to outside unit and wait 30 seconds and turn the breaker back on. Get a water hose and rinse off the coil real good that helps a lot. Touch the outside thick pipe it should be real cold and outside fan motor should be throwing hot air. If this doesn't work then it needs more freon."
What??
bob22 is offline   Reply With Quote
Old 06-01-2011, 09:55 AM   #5
What??
What what biach? Take it if don't like it. 3 x fff u
Old 06-01-2011, 01:28 PM   #6
30 year tech
hvac122's Avatar
What?????
hvac122 is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Connecting main house to guest house... hlavine Building & Construction 31 03-28-2012 10:04 AM
House not cooling properly sayitaintso HVAC 2 05-11-2011 11:44 PM
Trane XR12 1.5 ton-Too small for my house? Badfish740 HVAC 7 09-23-2009 06:48 AM
I have Central Heating & Air, but house won't cool down..HELP!! exiledone1 HVAC 13 07-10-2009 11:09 PM
