Never Seen This Before. - HVAC - DIY Chatroom Home Improvement Forum
Old 08-29-2011, 09:04 PM   #1
I'm Your Huckleberry
Rewards Points: 2,270
Never seen this before.
It's on a Fedders condensing unit which also I've never seen before. What the heck is it? It's tied from one end of it to the other and to the herm and common on the capacitor.
Doc Holliday is offline   Reply With Quote
Old 08-29-2011, 09:05 PM   #2
JJboy's Avatar
Start cap
http://www.bestbuyheatingandaircondi..._Code=CAP53137
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
The Following User Says Thank You to JJboy For This Useful Post:
Doc Holliday (08-29-2011)
Old 08-29-2011, 09:09 PM   #3
Originally Posted by JJboy View Post
Start cap
We talking about the same thing? I'm talking about the little small gray can that's above everything else. Makes sense it'd be a start cap of sorts but why an extra one? It's not a super start cap is it, like a hard start?
Btw that was not the issue, the regular dual run cap was blown.
Old 08-29-2011, 09:15 PM   #4
JJboy's Avatar
Check the link. I saw once. I didn't have chance to test.
Old 08-29-2011, 09:34 PM   #5
JJboy's Avatar
The correct name is Thermister Starter Kit. We need to know how test it.
Old 08-29-2011, 10:10 PM   #6
Beats me. All I know is once I replaced the dual run cap the fan didn't start. Then I unhooked that thing completely and it all worked. I thought that something wasn't right as that was only hooked to the comrpessor, checked all terminals and realized the fan spade was loose and not contacting properly on the dual run so I removed that wire, bit down a bit on the spade with my Kleins to tighten it's grip, re-installed that thingamajig and everything worked so I left it online. Turned the system on and off, on and off and it was all good.
Old 08-30-2011, 07:24 PM   #7
An old Tradesmen
Rewards Points: 8,144
Soft start assist.
PTCR.
Old 08-31-2011, 01:27 AM   #8
Originally Posted by beenthere View Post
Soft start assist.
PTCR.
Would you mind explaining further? I've never heard of a soft start and I haven't a clue as to what PTCR stands for.
Thanks, Obie One.
p.s.-I had a Carrier 410-A 5 ton that I cleaned the coil on today and once I replaced and re-installed the lid/fan the flash code at the condenser control board was 72, thermal cutout. Huh?
I removed the 24 volts to said board in condenser for about one minute and sure enough it reset and came on.
yeah me.
Old 08-31-2011, 04:19 PM   #9
An old Tradesmen
Might want to read about it.
http://www.datasheetcatalog.org/data...y/305cseri.pdf
The Following 2 Users Say Thank You to beenthere For This Useful Post:
Doc Holliday (08-31-2011), JJboy (08-31-2011)
Old 08-31-2011, 06:00 PM   #10
JJboy's Avatar
You may like this Doc.
https://docs.google.com/viewer?a=v&p...4NTNj&hl=en_US
Old 08-31-2011, 08:54 PM   #11
I'm sure I would JJboy, but I can't sign in to my google account. I've forgotten my account name and password.
That other link that BT posted I need to go to school figure it all out. Sheesh.
Old 08-31-2011, 09:42 PM   #12
An old Tradesmen
Basically its just a shunt. that is opened when the thermistor heats up.
The Following User Says Thank You to beenthere For This Useful Post:
