Nest Version 2 Rheem Furnance - HVAC - DIY Chatroom Home Improvement Forum
Old 04-18-2013, 09:52 AM   #1
bryanp22's Avatar
Rewards Points: 290
Read post below.
bryanp22 is offline   Reply With Quote
Old 04-18-2013, 09:58 AM   #2
bryanp22's Avatar
Rewards Points: 290
[QUOTE="bryanp22"]I have a rheem classic 90 plus furnance with cheap Honeywell programmable thermostat. I had green, yellow, red and white at the thermostat. After installing the nest the furnance fan ran continuously. It indicated I had no fan control. I even added wired the extra blue wire as a common at the furnance and the nest without luck. The fan still ran all the time. I've attached screenshots of my furnance model number and the wiring on the furnance. Is this just an incompatibility with my furnance and the nest? The behavior of my current thermostat is when I turn the heat heat on it has a slight delay then the blower engages, but it does shutoff once it reaches the temp. My fan on both thermostats is set to automatic. If the nest won't work for me does an Internet enabled thermostat work that will? My only other option to try tonight is try the nest again without the green wire and see I'd the furnance turns the fan on by itself. I'm thinking I must have a variable speed fan and nest just doesn't know how to use it and my current thermostat just doesn't use the variable speed either but I am unsure how to confirm that.
Nest version 2 rheem furnance-image-870388460.jpg   Nest version 2 rheem furnance-image-3493283747.jpg   Nest version 2 rheem furnance-image-3416053000.jpg
Old 04-19-2013, 05:54 PM   #3
bryanp22's Avatar
Rewards Points: 290
Returned the nest for a honeywell with wifi and its fine.
The Following User Says Thank You to bryanp22 For This Useful Post:
hvactech126 (04-20-2013)
Old 04-20-2013, 08:19 AM   #4
AKA HVACTECHFW
Rewards Points: 1,208
Nest has a LOT of issues... glad to see you made the right choice by dumping the nest and using a time tested and true manufacturer.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
My Furnance has stopped working DIY_user HVAC 7 12-20-2012 07:50 PM
Undecided between Lennox 13SEER / 11EER 13GCSX or Rheem 14SEER / 12EER RRPL Sommalina HVAC 2 10-05-2012 06:51 PM
Rheem Water Heater Questions 1972gs455 HVAC 0 01-15-2010 09:44 PM
WASPs under our deck.... diyntn Pest Control 40 01-01-2010 09:12 AM
Furnance question. diy4life Building & Construction 29 12-01-2009 05:39 PM
