Old 07-08-2012, 03:00 PM   #16
An old Tradesmen
Nest compatibility - Extra wire makes my furnace non-compatible?
Go to the furnace and look to see where the wire designated as "4" is connected. Its probably a common.
Old 07-08-2012, 04:48 PM   #17
I didn't post the model because I have no idea what it is. There's a name there, but not an identifiable model.
Here are the pictures.
squal is offline   Reply With Quote
Old 07-08-2012, 04:53 PM   #18
E2 Electrician
stickboy1375's Avatar
Terminal (4) is Rh, you are good to go with the NEST, enjoy, you're going to love it.
Old 07-08-2012, 04:56 PM   #19
JJboy's Avatar
Connect like this:
Old - New
G - G
Y - Y
W - W
RC - R
You don't need this jumper RC - 4 for your new thermostat
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
The Following User Says Thank You to JJboy For This Useful Post:
squal (07-08-2012)
Old 07-08-2012, 04:57 PM   #20
E2 Electrician
Make sure you mark those wires ONE at a time as you remove them. And as stated, you don't jump out Rc & Rh with the NEST, just terminate the current Rc wire on your old thermostat to Rh on the NEST terminal board, the NEST will automatically jump out Rc & Rh internally.
The Following User Says Thank You to stickboy1375 For This Useful Post:
squal (07-08-2012)
Old 07-08-2012, 05:25 PM   #21
Thanks Stickboy. And thanks everyone else for the help.
Old 12-18-2012, 01:59 PM   #22
Hey there... hope you dont mind the question but it is related.
We have a Lennox hi eff furnace with a carrier control panel (at the furnace) & a thermostat on the wall in our living space. How can I connect a Nest to this when all my wires are in the basement in the control panel? I have pic to email you if needed.
al
Nest compatibility - Extra wire makes my furnace non-compatible?-1.jpg   Nest compatibility - Extra wire makes my furnace non-compatible?-2.jpg
amcintyre is offline   Reply With Quote
Old 12-18-2012, 02:09 PM   #23
An old Tradesmen
Have to pull a new thermostat wire up to the thermostat.
Old 12-18-2012, 02:15 PM   #24
Hey thanks, I thought so but didn't trust myself.
What are the black & white wires on the lower left on the controller that run up to the thermostat.
Thanks...
Al
Old 12-18-2012, 02:19 PM   #25
An old Tradesmen
The power wires from the module to the stat.
The Edge is a communicating thermostat.
Old 12-18-2012, 02:22 PM   #26
S I only need the bundle of coloured wires from the furnace to the nest. Thus the 2 wires in the carrier control panel will be out of the picture?
Old 12-18-2012, 02:26 PM   #27
An old Tradesmen
Yep..
The Following User Says Thank You to beenthere For This Useful Post:
amcintyre (12-18-2012)
Old 12-19-2012, 11:51 AM   #28
(post deleted)
av-geek is offline   Reply With Quote
Old 12-19-2012, 12:33 PM   #29
Roofmaster
It is what it is? Well what the hell is it?
If Doc dosen't know, it cant be all that common. How about one of you chosen, enlightening the rest of us peons?
" A lot of men build things, and a lot of things fall down "
Old 12-19-2012, 07:18 PM   #30
Professional
what?!
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
Brand new Coleman 97.5% furnace makes horrible whining noise junebuggy HVAC 7 05-07-2010 11:24 AM
How to wire up furnace fan to kick in when humidity drops? Tryvidy Electrical 3 04-20-2009 04:53 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
