Neither AC Or Heater Will Turn On - HVAC - DIY Chatroom Home Improvement Forum
Old 04-06-2008, 03:36 PM   #1
Neither AC or heater will turn on
I have a comfortmaker unit that came new with the house in 2000. My problem is that it neither the AC or the Furnace will cut on by adjusting the thermostat. I can get both to come on IF I go in the attic, cut the power off to the unit, and then cut it back on. If I do that, the furnance and/or AC will run for one cycle, but not again unless I go back in the attic to 'reset' it. Initially, I thought it might be the thermostat, but after I reset it, I can control unit on the initial action after I reset it. Thanks in advance for your help.
To my knowledge, there's no LED to guage what the problem may be. It's possible that I dont know where to look for it though. If I take the cover off, there's no light or anything.
homebuilderinatlanta is offline   Reply With Quote
Old 04-10-2008, 09:46 AM   #2
Too many things could cause this for a diy to check without proper training and tools. You should call a tech.
statman is offline   Reply With Quote
"sticky" gas water heater thermostat homer12 Appliances 8 01-25-2008 04:36 PM
Water heater problem bear1957 Plumbing 23 11-01-2007 03:53 PM
help to diagnose pilotless heater problem jpplumber HVAC 30 01-02-2007 08:11 AM
Baseboard heater Help! jweinstock Electrical 6 10-28-2006 04:01 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
