Neil Gas Residentail Furnaces - HVAC - DIY Chatroom Home Improvement Forum
Old 12-20-2013, 07:55 AM   #1
neil gas residentail furnaces
Should the combustion blower continue running once the burner is lit?
It seam to waste a lot of heat out the vent!
Lyle gilleran is offline   Reply With Quote
Old 12-20-2013, 08:01 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,826
Is it a Heil furnace? that fan provides air for combustion and to push the smoke out and is necessary to run. no air=no combustion.
The Following User Says Thank You to yuri For This Useful Post:
carmon (12-20-2013)
Old 12-20-2013, 06:45 PM   #3
Experienced HVAC Tech
HVAC1000's Avatar
Originally Posted by Lyle gilleran
Should the combustion blower continue running once the burner is lit? It seam to waste a lot of heat out the vent!
it is that way on ALL modern furnaces. Even high efficiency.
HVAC1000 is offline   Reply With Quote
The Following User Says Thank You to HVAC1000 For This Useful Post:
carmon (12-20-2013)
Old 12-20-2013, 09:25 PM   #4
Rewards Points: 582
no combustion blower ..run...no heat...period. either before ignition or after..
The Following User Says Thank You to ben's plumbing For This Useful Post:
carmon (12-20-2013)
Old 12-20-2013, 09:30 PM   #5
biggles's Avatar
you could heat another house with what goes up the flue pipe...that round thing on the burner compartment doesn't feel air pressure the show shuts off.... check the furnace tag on the BTU rating and see what is used with thet lower number
any new technology in oil furnaces? av-geek HVAC 0 11-12-2012 12:54 PM
Dual Furnaces mcatlett HVAC 1 07-30-2012 03:56 PM
I have a Coleman Furnaces DGAA077DTB and I want to install a A/C unit to it. yoshua HVAC 1 06-14-2011 11:19 PM
Twinned Furnaces Questions MrControls HVAC 12 12-13-2008 10:09 AM
2 furnaces 1 thermostat clarnp49 HVAC 3 12-05-2007 08:12 PM
