Neil Gas Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 12-07-2011, 03:19 PM   #1
neil gas furnace
i have a 4 yr old gas furnace. The problem i have is that the thermostat shows the heat is on ,but the furnace is not . So what i have to do to get it going again is to reset the breaker. And then the furnace is fine for a couple of days. And it starts over again. Not sure if its my thermostat or furnace.
M.A.D is offline   Reply With Quote
Old 12-07-2011, 05:28 PM   #2
biggles's Avatar
remove the sdtat off the subbase and jump R to W see if you get a complete control with the jump if it doesn't come on with the jump it's something within the furnace..especially with that resetting your doing with the stat mounted..
Old 12-07-2011, 06:06 PM   #3
Have you done the annual maintenance yet this year? If not that's a good place to start.
Furnace Model # Feh-015-04 clicking but not turning on? haimei HVAC 1 12-14-2010 05:01 PM
Payne PG9YAB high efficiency 95% furnace water draining problem jchen64 HVAC 9 12-06-2010 06:42 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
Problem with Trane gas furnace quovadis HVAC 17 12-22-2008 01:12 PM
Olsen BFL 120 Furnace DaleB HVAC 12 12-19-2008 10:42 PM
