Negative Pressure - What Are My Options - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-23-2011, 08:58 PM   #16
Leaks
I have single pane windows and one was broken this weekend. I covered it in plastic and found that I had a significant negative pressure in the house, drawing in outside air. After inspecting the duct work, I found a significant leak where the package unit heat pump (outside) connects to the duct work. Taping this up corrected the negative pressure in the house. This can cause significant performance problems, especially if the only source of air is drawn in from the attic space through the exhaust fans openings and other leaks in lighting or attic access doors.
mar0isa is offline   Reply With Quote
Old 07-24-2011, 11:59 AM   #17
Rewards Points: 1,512
Originally Posted by Jguerriere View Post
IMy understanding is the HVAC system should be like a pump in a pool where the pump is taking water out and returning it to the pool.
My return takes air out of the house. It heats and, then then returns the very same air back into the house via the vents.
The house should not go negative unless some of the air is not making it back in. That is my understanding of the physics.....
This is the correct behavior.
Which way is the drop cloth diaphragm being pulled and which system is doing it?
If supply air (after cooling or heating) is being blown into the crawl space then you want to stop that, not add a return in the crawl space.
Tags
hvac , negpressure
Boiler pressure troubles jduffett HVAC 2 12-12-2010 07:15 AM
Intermittent Low Water Pressure Fox Plumbing 4 03-02-2010 06:04 AM
Could lack of soffit venting increase indoor negative air pressure? creamaster Roofing/Siding 1 03-07-2009 01:27 PM
Heating question, negative pressure 2nd floor Shamus HVAC 8 10-04-2008 11:24 AM
negative pressure novice General DIY Discussions 6 02-08-2007 08:02 PM
