Old 11-20-2009, 06:16 PM   #31
It was a dark and stormy
Yoyizit's Avatar
need some help identifying my system
Does recovery rate have a meaning for these boilers?
With these kw usages it's the same as a tankless WH.
Old 11-20-2009, 06:48 PM   #32
An old Tradesmen
Oil at 60% combustion(SSE) efficiency.
Electric must be less then:
$0.06 KHW with oil at $1.475 a gallon
$0.07 KHW with oil at $1.720 a gallon
$0.08 KHW with oil at $1.965 a gallon
$0.09 KHW with oil at $2.215 a gallon
$0.10 KHW with oil at $2.460 a gallon
$0.11 KHW with oil at $2.705 a gallon
$0.12 KHW with oil at $2.953 a gallon
$0.13 KHW with oil at $3.195 a gallon
$0.14 KHW with oil at $3.445 a gallon
$0.15 KHW with oil at $3.691 a gallon
Oil would have to be very inefficient, for electric to be cheaper then oil.
Don't forget. You shouldn't be comparing an inefficient oil boiler, to a new electric boiler.
Have to compare a new oil boiler to a new electric furnace.
Old 11-20-2009, 07:01 PM   #33
Hvac Pro
If he wants to not have oil tanks or oil at all then an electric boiler may cost less to run than the "old beast".
Old 11-20-2009, 07:04 PM   #34
An old Tradesmen
Using a 3 pass 87% efficient oil boiler, electric would have to be less then:
$.06 KWH with oil at $2.140
$.07 KWH with oil at $2.495
$.08 KWH with oil at $2.854
$.09 KWH with oil at $3.211
$.10 KWH with oil at $3.568
$.11 KWH with oil at $3.925
$.12 KWH with oil at $4.282
$.13 KWH with oil at $4.639
$.14 KWH with oil at $4.996
$.15 KWH with oil at $5.352
Keep in mind. that the electric rate on the left of an oil price. Is at what point its cheaper. By a couple cents, for the year.
Old 11-20-2009, 07:06 PM   #35
An old Tradesmen
Doubtfull electric would be cheaper, then that boiler.
And if its a lot more expensive. Then his tenants may have to choose between paying for their electric so they can have heat. Or paying rent.
If they have to decide. I bet they decide to have heat, and worry about eviction later.
Old 11-20-2009, 07:14 PM   #36
Hvac Pro
Thermolec is right across the street from him. LOL. I would visit them and they probably have some engineers who know his market and can give him the best answers or someone at Hydro Quebec. One of my customers says gasoline/oil is going up soon. They usually speculate on how severe the Winter is going to be and try fleece everyone..
Good thing I have the "company" van to grab the "occasional" bag of groceries with.
Old 11-20-2009, 07:21 PM   #37
An old Tradesmen
When I use to work for a company. I would stop at a grocery store on the way home.
I wish the OP, would post his electric rate.
Down here. Some landlords. Have the oil heat pulled out and electric heat installed. instead. Trying to tell us, or their tenants that it will be cheaper heat for them.
When they are really just trying to stop having to pay for repairs bills on the oil heat.
Old 11-20-2009, 07:39 PM   #38
Hvac Pro
I have only seen a few electric boilers. Do you have experience with them? I assume they use immersion elements and do they get corroded/fail? Fresh water if added every year or 2 may be a killer.
Old 11-20-2009, 07:56 PM   #39
An old Tradesmen
Worked on some for commercial heating(300KW is the largest I ever worked on).
And some for steam rooms(11, to 27KW).
Most of them, look just like a bolt on element for a water heater.
Old 11-21-2009, 08:50 PM   #40
Hi again,
Thanks for all the responces and feedback. Very handy to hear everyones opinion. As for my electric rate, I looked at my most recent statement, and got the following info...
For the past 377 days, Ive used 9450 kWh, at a cost of $763.57 CAD, so works out to about 0.0808 $/kWh. I just had my oil tank filled, and paid $458.50 CAD for 583.3 Litres (about 154 gallons) @ .70 a litre plus tax. The highest Ive paid for oil is about .87 $/L, and that was last spring when oil was very high.
.87$/l = about 3.30 cad a gallon or about 3.15 USD/Gallon
.70$/L = about 2.65 cad a gallon or about 2.53 USD/Gallon.
sbmfj is offline   Reply With Quote
Old 11-21-2009, 10:49 PM   #41
An old Tradesmen
Your last fill, was a short fill.
At that fills oil cost. And your posted electric rate.
At 80% eff for the oil. The oil would be about 18 bucks cheaper then electric.
At 75% eff, the oil would be 7 dollars more then the electric.
At 70% eff, the oil would be 35 dollars more then the electric.
Old 11-22-2009, 08:39 PM   #42
thanks Beenthere. Mind sharing your formula?
Old 11-22-2009, 10:17 PM   #43
An old Tradesmen
I have them in a spread sheet, that does all the work for me.
I just enter the total BTUs until I get the gallons you posted, and then enter the rates, and efficiencies.
I'll see if I can break out some of the formulas tomorrow, to make it easier for you.
Old 11-23-2009, 12:30 PM   #44
thanks Beenthere. Youve been very helpful!!
Burnham Series 2 Cast Iron Radiator System SybrDave HVAC 2 12-10-2009 06:24 AM
new system install.....questions firedogut HVAC 4 10-04-2009 08:10 PM
Installing a New Central Air System vdu HVAC 7 09-01-2009 04:45 PM
Hot Water Heating System in older house GrannyAnnie HVAC 2 08-31-2008 05:50 AM
New House, new system, poor cooling Faulknertw HVAC 15 07-08-2008 11:06 PM
