Need Some Help With Boiler Installation - HVAC - DIY Chatroom Home Improvement Forum
Old 03-03-2013, 09:26 AM   #1
Question
Need some help with boiler installation
Hi! I need some help here with installation of a Weil-Mcclain boiler. I bought the WTGO-4 boiler. When I tried to install it, I noticed that one of the hot water outlet is a steel pipe without any thread while the return is threaded inlet. I am completely confused here. Why Weil-Mcclain did not thread the hot water outlet? Is this normal? Can any pros give me some help here? I do not get it why Weil Mcclain did not thread the outlet.
Right now I have no heat for my house. I desperately need some help to get the installation going forward.
Thanks for any help here.
yi
helpme2013 is offline   Reply With Quote
Old 03-03-2013, 10:02 AM   #2
An old Tradesmen
Rewards Points: 6,086
Just screw it out. Its not meant to be a nipple for you to use. You use what ever size nipple/pipe you need for the application the boiler is being installed in.
Old 03-03-2013, 10:14 AM   #3
The package does come with a flange. All right I am going to try it. THANK YOU VERY MUCH. Really appreciate your help,
yi
Old 03-03-2013, 12:13 PM   #4
I tried to screw a nipple in there. It just does not have the bite to go in. Does all boiler come with a unthreaded piping inlet or outlet. Why can Weil-Mcclain just thread the water inlet or out let at the 1st place?
Old 03-03-2013, 03:29 PM   #5
An old Tradesmen
After you remove the pipe another one should screw in without a problem.
Its the way Weil McLain does it.
Other boilers come with no nipple in the tap/port.
Old 03-03-2013, 08:43 PM   #6
Rewards Points: 610
Yi..make sure you are using correct pipe nipple..must be NPT (National Pipe Thread) the threades are tapered. and are..available from most plumbing supply stores..Also make sure you are lining it up straight when installing..also put pipe thread compound on the threads before connecting...do you have the right size nipple...check boiler specs/take shipping nipple into store with you to compare...should be easy to connect...if not then, threads on boiler may be damaged/cross threaded.
techpappy is offline   Reply With Quote
Old 03-03-2013, 10:20 PM   #7
Roofmaster
Rewards Points: 2,172
Sounds like they might be damaged now. Hope he didnt cross thread it. Why do they do this, for a lifting point? I would have expected a hex headed plug.
Probably for a pressure test with a shark bite type coupling huh?
Old 03-03-2013, 10:44 PM   #8
An old Tradesmen
They may use it for a hydrostatic test in the factory. But its not used for anything in the field.
Old 03-04-2013, 06:36 AM   #9
Thanks for all help. With all your suggestions I realized that the piece of steel pipe does not belong there. It must be for the pressure testing at Weil-Mcclain. Somehow Mcclain forgot to take it out or to save time and left there on purpose. I hate Weil Mcclain because I wasted all my time to figure out how to mount the TACO pump onto a piece of pipe which was not supposed to be there. Make you feel you are so stupid.
Anyway thank you all for all your help. Really appreciate it.
yi
Old 03-04-2013, 09:22 AM   #10
Engineer
The nipple is there to keep the boiler centered within the shipping crate, its a shipping nipple only. If you got stuck on that dilemma how's the rest of the install going?
Lee H is offline   Reply With Quote
The Following User Says Thank You to Lee H For This Useful Post:
helpme2013 (03-04-2013)
Old 03-04-2013, 10:31 AM   #11
I was not sure what that piece pipe for. and afraid unscrewing it may damage the body of boiler. The whole boiler manual did not mention that the installer should unscrew that piece pipe and to put a real nipple there, then to install the TACO pump.
I was pretty mad with the fact that Weil-Mcclain wasted my whole weekend to figure out what that piece pipe for. I have to go to NJ to work. I will install the boiler this weekend. I am thinking it may take me half day to put the system to work.
Thanks for the help.
yi
Old 03-04-2013, 11:52 AM   #12
HVAC Tech/Owner
Rewards Points: 604
yi
Wonder what else the manual doesn't explain on a boiler install...
Post some pics!!
Technow is offline   Reply With Quote
Boiler btu rjordan393 HVAC 2 12-12-2011 11:41 AM
NTI NY Thermal Trinity Gas Boiler zildj HVAC 0 12-11-2011 03:40 PM
Help contemplating new boiler & system in general wombosi HVAC 1 06-18-2011 11:54 AM
Oil fired boiler leaking water! frankm1960 Plumbing 11 03-18-2011 10:03 AM
Boiler Installation - Am I being gouged? mahatmakain HVAC 55 01-29-2010 04:38 AM
