Need Some Help With Blower Motor - HVAC - DIY Chatroom Home Improvement Forum
Old 05-02-2012, 08:13 PM   #1
Need some help with blower motor
My old hot air furnace blower motor died so I pulled it out and purchased a new one. The old motor was an Emerson Mod SA55NXWR-4554, 1/2 HP, 1725 RPM, 115v, 7.8 amps single phase. The replacement motor specs are the same but it is a Dayton brand 5K258K.
The wiring diagram on the housing is limited to just the rotation of the motor and where the two electric wires connect. All is described in a number for each post.
My issue is after wiring it up and connecting, it is not spinning the blower as fast as it should be causing the furnace to overheat and shut down.
There are another set of posts inside the wiring port with numbered 3 but there is no reference to what these are for.
I am concerned that I bought the wrong motor or I'm missing something in my wiring.
Guys PLEASE help.
Chris85 is offline   Reply With Quote
Old 05-02-2012, 08:23 PM   #2
Rewards Points: 616
what makes you say its spinning to slow...
carmon is offline   Reply With Quote
Old 05-02-2012, 08:24 PM   #3
biggles's Avatar
thats a single speed motor as shown. the correct direction when on...how a many wires on the old motor? is it for just a furnace with no AC? http://www.grainger.com/Grainger/wwg...rue&sst=subset
Old 05-02-2012, 09:09 PM   #4
An old Tradesmen
Rewards Points: 6,500
Just a wild guess. But maybe its spinning in the wrong direction. Check and I bet its running in teh wrong rotation. You should see instructions for changing its rotation.
Old 05-02-2012, 09:28 PM   #5
how
Rewards Points: 1,102
If you left the blower cage inside the fan housing and only changed the motor then briefly turn on the fan blower to see which way it's turning....
If the scoops of the blades of the blower cage are facing the same direction that the fan is turning towards, the motor is running in the correct direction.
If the rounded side of the blades are facing the same direction that the blower is turning, then the motor direction is backwards.
how is offline   Reply With Quote
Old 05-02-2012, 10:07 PM   #6
thank you!
WOW do I feel like a horses A**..yup it was spinning the wrong way.
Thanks guys for the help, sincerly !
Old 05-02-2012, 10:38 PM   #7
Rewards Points: 582
Guys PLEASE help.
are you sure the rotation is correct....most dayton motors are reversible by switching wires....picture would help...ben..
Old 05-03-2012, 05:06 AM   #8
An old Tradesmen
You aren't the first person to have made that mistake.
Of course, I never did. :w histling2:
Old 05-03-2012, 08:09 PM   #9
Rewards Points: 582
me neither
Trane XL80 blower motor part number? keverino HVAC 17 01-10-2012 10:01 AM
Old Rheem Air Blower Motor Wiring Problem CompoundNetwork HVAC 3 11-20-2011 04:51 PM
Blower motor: Emerson to GE threeonesix HVAC 12 08-25-2011 04:59 PM
Wiring a replacement blower motor bodtchboy HVAC 17 08-11-2011 11:05 PM
Inside Blower motor keeps running crawlerchris HVAC 1 12-19-2009 09:01 PM
