Old 05-22-2009, 06:22 PM   #1
Default Need some friendly advice-- Coleman/York v. Trane
Hi. I'm replacing my split system furnace (gas) and AC. Live in a split level home (in NJ) and suffer from lack of heat and AC "upstairs" and too much hot/cold downstairs (seems to be common problem in splits). I've narrowed it down to the following systems: Trane XC-95 (80K BTUs) & XL-16i (3 ton) v. Coleman/York Echelon/Affinity 9.M/9.C & 8T/8T.
The Coleman/York units will run me about $4,200 less (quotes are about $2,500 less and then Coleman/York has a $1,700 rebate). Assuming the Trane products are even better to begin with (and I'm not sure if that's accurate--I've read some good things about the Coleman/York units I'm interested in--I also called Johnson Controls tech support and they insisted that the Coleman and York are same quality), is Trane actually "worth" that much more?
In addition, the Coleman/York furnace is a "modulating" furnace which, is that better than a variable speed staged unit (like the Trane) for a split level home (i.e., will it keep steady heat at low level so I'll have heat longer & also be more efficient).
Any thoughts? Any expert guidance would be GREATLY appreciated. Thanks.
biggerdaddynj is offline   Reply With Quote
Old 05-22-2009, 08:04 PM   #2
An old Tradesmen
Double check, that the York/Coleman dealers are including the require IAQ upgrades and thermostat needed to get the 1700 dollar rebate.
With a York/Coleman mod, you'll havde a more even heat then with the Trane.
York/Luxaire/Coleman, they all are mad ein the same factory, on the same assembly lines.
Old 05-22-2009, 09:40 PM   #3
Thanks, beenthere. I'll check on the IAQ and thermostat upgrades. Appreciate the advice.
More On This Topic
Two Aces in Blackjack
Two Aces in Blackjack by Expert Village
Right now I’m going to show you what happens if a player gets two aces up, which is very exciting. Okay, here’s an ace, and here’s another ace. Okay, here we have dealt two aces to the player, and we’re going to put a chip in... Read More »
Hi! This is Jon on behalf of Expert Village. In this video clip I will be showing you how to check your furnace filter. The first thing you need to do is locate your furnace. Now in many houses, the furnace is located in the laundry room which is in the... Read More »
Ice fishing is a popular pastime in the northern states where the lakes and rivers freeze. The ice fishing houses range in sophistication from a little pup tent to a fully built, functioning home. There are several ways to heat the ice fishing house... Read More »
Before you call someone to come fix your furnace, you may want to find out what's wrong. Read on to learn how to check your furnace for any possible malfunctions. Read More »
Hi, this is Jon on behalf of Expert Village in this video clip we'll be changing our furnace filter. Now right before winter I always recommend to people to go ahead and change out their old furnace filter with a new one. On this unit our furnace filter... Read More »
Advice on replacement system Wayne09 HVAC 9 04-03-2009 10:47 AM
Need some advice for a bunch of things. ingeborgdot Home Theater 11 02-12-2009 09:48 AM
Trane heat pump & air handler or another brand? imola ghost HVAC 0 08-26-2008 10:02 PM
Electrical Advice Caution!!! Mike Swearingen Electrical 12 03-05-2008 01:51 PM
Humid - Switched Trane xl1200 AC for a Payne HP - now very Humid dagrappler HVAC 1 06-11-2007 02:16 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
