Need Rigid Pipe Assembly Tips - HVAC - DIY Chatroom Home Improvement Forum
Old 01-05-2010, 03:17 PM   #1
Rewards Points: 280
What is the correct procedure to assemble rigid HVAC pipe?
I have 10" x 60" rigid pipe that I picked up at the local home improvement store. The pipe is flat, not in its final circular form. I see where the ends interlock together to form the circle.
Is that it?
Is it best to add a sealent or mastic into the groove before snapping together?
Are screws added to keep the circle from comming appart?
Anyone know of a website that may explan the procedure?
THanks.
Earnie is offline   Reply With Quote
Old 01-05-2010, 05:18 PM   #2
An old Tradesmen
Rewards Points: 6,516
Put it together. And then mastic it.
Can use mastic tape.
Old 01-05-2010, 05:30 PM   #3
Rewards Points: 280
Thanks BT.
How to stop sump pump discharge pipe freezing??? relbeig Plumbing 8 11-12-2012 01:03 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
Need Tips To Unscrew 30-year Frozen Brass Pipe Fixture artdunbar Plumbing 4 03-12-2009 12:38 AM
Septic/sewer pipe replacement Mendocino Plumbing 4 11-21-2008 06:40 PM
Furnace Venting Requirments jamiedolan HVAC 9 11-18-2008 06:40 PM
