Need To Replace Floor Decking Under Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 02-18-2008, 10:21 PM   #1
need to replace floor decking under furnace
I have an Intertherm forced air furnace that has had a problem of dripping condensation over last 4-5 years from the A coils down onto the fan/blower and then leaking on the floor.There is a pan under the blower but it is not a solid pan. The floor decking needs to be replaced under it. I would like to pull it out myself and replace the wood,put in a proper drip pan and replace. I have had it serviced every year by an authorized service company and nobody has been able to correct the condensation problem.One guy even called Intertherm to see if they had any ideas (did,but didn't work).I would also like to correct the dripping problem,if possible,as is a fire hazard.The unit is still in good working order and would rather not replace at this time.
Any suggestions/tips on pulling it out?Can't find a manual anywhere to show installation.
Thanks.
pdsullivan is offline   Reply With Quote
Old 02-19-2008, 06:33 AM   #2
Can you post a picture of your furnace, so I can see it with a plenum and cold air boot?
gena is offline   Reply With Quote
Old 02-19-2008, 08:08 PM   #3
photo as requested
I have attached a photo of the furnace and A coils as requested. At least I hope I have.
Parker
Old 02-19-2008, 09:28 PM   #4
I think you have to hire a contractor to pull out/replace this air handler, because you can’t cut the line set by yourself.
Old 02-20-2008, 09:15 PM   #5
coolmen's Avatar
pay to have the thing taken out to the junk yard. then have something installed that wont leak water and cause health problems.
coolmen is offline   Reply With Quote
Old 02-21-2008, 10:05 AM   #6
Charley B's Avatar
Originally Posted by gena View Post
I think you have to hire a contractor to pull out/replace this air handler, because you canít cut the line set by yourself.
That would be correct the freon lines and A-coil has to have the freon pumped down and the line set cut to remove the furnace not something the average person has the tools and or knowledge to accomplish.
Charley B is offline   Reply With Quote
Old 02-21-2008, 02:42 PM   #7
Thanks. I will contact a HVAC company.
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 08:01 PM
Replace a furnace blower motor dadncharge HVAC 2 12-06-2007 10:42 PM
Furnace blew up, need to replace heat and air with single unit. d_Random HVAC 2 02-06-2007 05:18 PM
Replacing My Furnace, few simple questions compression HVAC 10 02-03-2007 06:00 PM
Replace furnace, coil and duct system sps123 HVAC 2 01-07-2006 11:56 AM
