Need To Remove Old Humidistat - HVAC - DIY Chatroom Home Improvement Forum
Old 04-25-2012, 01:29 PM   #1
Rewards Points: 16
Need to remove old humidistat
I just bought a home and several years ago the former owner replaced the furnace. The old furnace had a humidifier on it.
Now the hallway has both a honeywell round thermostat and an old, useless humidistat on the wall. Problem is I want to upgrade to a programmable thermostat but there is no room for one where the current round one is (between the humidistat and a door jamb).
I haven't touched the humidistat, but I'm guess it comes off like a termostat? The real question is what wires are attached and what will I need to to do with them? Are they potentially live?
Not sure if this is HVAC or electrical, but I thought I'd try here first. Any help is appreciated. Thanks!
dublozrow is offline   Reply With Quote
Old 04-25-2012, 05:18 PM   #2
An old Tradesmen
Rewards Points: 6,598
Should only be 2 wires. And they should have been disconnected at the furnace when the humidifier was removed.
They would only be 24 volts if they wee still connected. but its best to look for them near the furnace and make sure they are disconnected, so you don't short them and burn up a transformer on your furnace.
How do you remove a wood stove and bricks from living room? SimpleJack Remodeling 13 08-28-2011 02:26 PM
Wrong Sealant used on Unfinished Ceramic Tile... how to remove?! flipjarg Flooring 3 02-15-2010 10:09 PM
best way to remove areca palm root system Dus Landscaping & Lawn Care 0 01-23-2010 10:40 AM
Frigidaire/can't remove front water/ice dispenser tigerfan44 Appliances 0 12-17-2009 11:45 PM
How can I remove my gutter / apron with out pulling the first row of shingels wamyers92 Roofing/Siding 3 07-02-2008 03:10 AM
