Old 09-20-2005, 03:01 AM   #1
Arrow
Need to remove old central air unit
:D I have purchased a new central air unit and I need to remove the old central air unit. How do i depressurize the compressor?
pmb003 is offline   Reply With Quote
Old 09-21-2005, 01:06 AM   #2
Contractor
Today, you need a licensed pro with recovery equipment. The days of 'lettin it fly' are over.
Teetorbilt is offline   Reply With Quote
Old 04-28-2006, 03:33 PM   #3
can 't you tell him how to do it, without loosing any freon? Just do a condenser pump down? Is that not legal either?
didn'tdoit is offline   Reply With Quote
Old 04-30-2006, 01:26 PM   #4
coolmen's Avatar
Cool
install gauges, back seat (close)Liquid line, close off suction side 1/4 to 1/2 way. operate condenser. the gauge preasure readings wil steadaly drop toward 0 psi.when you get to 0psi close off the suction side quickly the rest of the way and shut off condenser. your done
coolmen is offline   Reply With Quote
Old 05-03-2006, 05:05 PM   #5
If you can, keep the unit and bring it to a junk yard if you have one near by. You won't get rich but you can make a few bucks on the copper etc in the unit. Mind you, if you have a pick up truck that makes it easier and less hassle.
Alyssa is offline   Reply With Quote
Capacitor Replacement on Central Air unit sn2567 HVAC 6 07-21-2012 03:29 PM
Used Central Air Unit? shep28 HVAC 2 04-21-2007 08:59 PM
central air unit question princessme HVAC 4 07-08-2006 10:13 PM
Removing Refridgerant from Central Unit wackerjr HVAC 1 06-23-2006 03:09 AM
