Need To Redo Some Type B Venting That Has Screws - HVAC - DIY Chatroom Home Improvement Forum
Old 07-15-2011, 04:59 PM   #1
Rewards Points: 1,062
Question
need to redo some type B venting that has screws
i decided to redo some type B venting in which i already put screws in order to stop upstream joints from twisting. i used 1/4" screws. was wondering if those holes will be an issue if i just leave them and put new screws in other places more convenient to the new layout.
thanks
Old 07-15-2011, 05:19 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 174
the moisture in the flue gas will eventually corrode those holes larger and larger. I would leave screws in them or seal them with silver foil tape or red rtv high temp silicone. small pieces of silver foil tape from HDepot on the joints would be better than perforating any B vent. it is NOT supposed to be perforated. the type we use has spring loaded clamps to hold the sections together and they don't slip when installing due to the pressure of the clamps.
The Following User Says Thank You to yuri For This Useful Post:
amakarevic (07-15-2011)
Old 07-15-2011, 05:29 PM   #3
the silver foil tape solution seems the best. thanks
Old 07-15-2011, 09:30 PM   #4
Just make sure whatever you use is fire rated.
Artco is offline   Reply With Quote
The Following User Says Thank You to Artco For This Useful Post:
amakarevic (07-16-2011)
Tags
vent pipes
Composite vs wood deck screws cranedk Building & Construction 6 11-26-2015 03:47 PM
Screws for IPE decking rocketdoctor Building & Construction 3 09-08-2009 08:49 AM
New Trex Deck just installed with wood deck screws instead of composite- HELP PLEASE! JLayman Building & Construction 3 08-07-2009 10:20 PM
New Drywall Installation, 1 joint screws are popping zjowens Drywall & Plaster 29 01-02-2009 12:26 AM
Venting of Cathedral Ceiling on Shed type roof sandyman720 Roofing/Siding 7 08-02-2007 10:27 PM
