Need Rec On 22 Amp Programable Thermostat - HVAC - DIY Chatroom Home Improvement Forum
Old 09-30-2010, 01:27 PM   #1
Need rec on 22 amp programable thermostat
I have 5 1000 watt ceramic panel heaters in a sun room, and would like to replace the current thermostat with a programmable model. 5000 watts / 240v = 21 amps. (As a side note, it appears as if the contractor who installed the system used an undersized thermostat because the wires at the connection show signs of overheating.) There are 2 10g wires that supply the power in conduit, and there is a box that houses the current thermostat.
I'm having difficulty finding a line-load thermostat that can handle this much current -- most that I have found tops out at 3800 watts/16 amps.
Any suggestions?
One potential alternative I'm considering is to replace the line-load stat with a 240v DPST relay and a conventional 24v programmable stat. If you think this would be a better alternative, I need recommendations for the combo relay/transformer. Thanks.
steve60069 is offline   Reply With Quote
Old 09-30-2010, 02:09 PM   #2
lloydb's Avatar
I instantly thought about putting a couple relays on a transformer. How about something like this?
http://hdsupplysolutions.com/webapp/...alog&langId=-1
Broken Arrow hvac Broken Arrow Air Conditioning
lloydb is offline   Reply With Quote
Old 09-30-2010, 02:47 PM   #3
An old Tradesmen
Rewards Points: 7,816
At 21 amps. 10 gauge wire is fine.
Probable another problem some where if the wires are over heating.
Carrier Edge Thermostat Installation Issue ptalar HVAC 1 07-13-2010 05:40 PM
Honeywell Prestige HD thermostat wiring 1H/1C + Humidification System TekGamer HVAC 0 07-09-2010 11:58 PM
Parts of a programable thermostat STUDENT101 HVAC 2 11-08-2009 08:12 PM
Wiring Programable Thermostat shellyprice Electrical 2 05-13-2009 08:06 PM
Wiring a Noma Programable Thermostat 111jag General DIY Discussions 1 10-14-2007 10:13 PM
