Old 12-02-2012, 11:52 AM   #1
Need pro's opinion on damage, etc...
I purchased my own heat pump and air handler online and had a local contractor install it. When brazing the lineset end near the air handler, the installer doing the brazing didn't have any wet rags or spray around the inside or outside of the unit. The foreman stopped him from brazing (he had already brazed the elbow-so 1300 F was applied to tube) and had him spray it down, It sizzled pretty good and for quite awhile. I could see the look off concern on the foremans face, no mistaking that. I don't know if they pulled the sensing bulb away or not because I didn't get a chance to look inside before the job was finished and covers put back on.
After they left I looked inside and discovered a big gash in the cooling fins on the A-Coil. See attached pics. They did have the coil out and had removed the horizontal drip pan. Someone did the deed and stuck the A-coil back in hoping I wouldn't notice I guess.
Anyone care to comment about all of this and assess my pics and severity of the damage to fins and possibly to TXV valve? Can you ascertain anything from the heat marks on the tube?
Thanks guys...
PS. Yes they did use nitrogen and evacuated the lines before filling with Puron.
Need pro's opinion on damage, etc...-dsc02632.jpg   Need pro's opinion on damage, etc...-dsc02621.jpg   Need pro's opinion on damage, etc...-dsc02610.jpg   Need pro's opinion on damage, etc...-dsc02607.jpg
jfls49 is offline   Reply With Quote
Old 12-02-2012, 12:11 PM   #2
Originally Posted by jfls49 View Post
After they left I looked inside and discovered a big gash in the cooling fins on the A-Coil. .
The few ruffled aluminum fins are not as big a deal as you make it out to be. That is not a big gash. As long as the copper tubing beneath the fins was not damaged, I do not think the ruffled fins are worth worrying about.
I cannot speak to the brazing of the lineset. Someone else will have to chime in on that.
hammerlane is offline   Reply With Quote
New Twist on Water Damage to Laminate Cruisecontrol Flooring 1 01-15-2011 03:52 PM
J-B Weld to Mount Metal Box HooKooDooKu Electrical 161 02-04-2010 12:12 PM
Need some advice on buying home termite & water damage. Mr Heshup General Discussion 1 03-29-2009 04:06 PM
Replacing Damage Planks in Laminate Floors manoa115 Flooring 1 09-18-2008 06:56 AM
