Need Pro Opinions On New Plenum Reducer??? - HVAC - DIY Chatroom Home Improvement Forum
Old 02-02-2009, 11:46 AM   #1
Need Pro Opinions on new plenum reducer???
Sorry I don't know how to rotate these attachments.
Is it just me or should this plenum be plumb and vertical, and yes.... it is also out of level by 3/8".
I envisioned a tapered transition to a vertical 8" to a 90 degree turn at bottom. The sheet metal work was completed after I was called away from the house during installation. Haven't spoken to the installer's boss yet. Wanted a pro opinion or two in advance. I think the end panels on the taper were reversed by acciednt during assembly.
My neighbour says it looks like something from Dr. Seus
Need Pro Opinions on new plenum reducer???-dsc_0106.jpg   Need Pro Opinions on new plenum reducer???-dsc_0107.jpg   Need Pro Opinions on new plenum reducer???-dsc_0108.jpg
Chemist1961 is offline   Reply With Quote
Old 02-02-2009, 12:29 PM   #2
An old Tradesmen
Rewards Points: 6,480
The reducing transition, needs to be spun 180.
Old 02-02-2009, 02:16 PM   #3
Thnaks BT Exactly my thoughts at first glance. If not the trans at least the end panels. This would correct the drop to near vertical.
Old 02-02-2009, 02:26 PM   #4
An old Tradesmen
End panels can't be moved by them selves.
The transition must be spun.
The angles are different degrees, so the length of the long sides are different.
Old 02-02-2009, 02:53 PM   #5
Yes,
They are now that they have been trimmed. What if that middle trunk section got flipped top to bottom and the angle cuts trimmed a bit. Problem here is there is also a front to back transition flare of about 2" on one end the front side of the furnace, so from a side view, the left side of the RA drops vertical, flush with the back of the furnace the right side flares out about 2" where it meets the extension above the 90 degree turn into the fileter box approx 24 inches above the floor. I can attach photos when I'm home later.
I think the young guy got his wires crossed. Is this more visual or will it reduce efficiency?
Old 02-02-2009, 04:00 PM   #6
An old Tradesmen
Its mostly cosmetic.
Minor resistance to air flow from direction changes.
Old 02-03-2009, 07:28 AM   #7
G71
Pro
Agreed, but it looks ridiculous, they should be happy to come back and fix it.
G71 is offline   Reply With Quote
Old 02-03-2009, 09:53 AM   #8
Yes, as mentined I was a bit perplexed when I came home and saw this and took out the tape measure and level.
My workmanship is my signature so I expect my upgrades to be done to my standard. I think he may have flipped the furnace 180 degrees as well
How many $ worth of sheet metal and time would this be to refit ?With the 90 turn the 8 x 24" plenum rises to about 5" above floor
Old 02-03-2009, 09:03 PM   #9
Git er dun
Love the Dr. Seuss reference! That is funny as heck. Although, I agree with just minimal resistance and aesthetics being the real issue, I would make them come back and fix. You have an installed rotated reducer on your hands.
todolist is offline   Reply With Quote
Old 02-03-2009, 09:37 PM   #10
Sent an email with photos to the shop today. Help is on the way
Thanks for the comments
Tags
duct , new furnace , plenum , sheet metal
Old Return air plenum for new furnace? Chemist1961 HVAC 1 12-25-2008 11:20 AM
Attaching plenum to furnace. hartkem HVAC 6 11-10-2008 03:17 PM
Removing Extended Plenum Calm_Blue_Ocean HVAC 15 01-07-2008 06:22 PM
Plenum - Where to buy? zootjeff HVAC 1 07-11-2007 09:21 PM
Plenum Design winkydink HVAC 1 11-22-2006 11:28 PM
