Need A Pro Here. - HVAC - DIY Chatroom Home Improvement Forum
Old 10-07-2012, 07:39 PM   #1
Rewards Points: 150
Need a pro here.
I built this fire place ,a full masonary one ,out of creek rock with a 11 inch square flue liner (rounded corners) and I'm thinking about putting 3/8th soft copper coil in the upper five feet of the liner, no brazing inside liner and connecting to a pump (what size)? and connecting all to the A coil thats never been used on the furnace. For the liquid I'm thinking about using cooking oil (the cheap stuff) that has a boiling point (smoke point) at 550f . Want the propane furnace as a back up ,but would like the blower to come on when fire place heat is needed. Any help please.
bernieb is offline   Reply With Quote
Old 10-07-2012, 07:53 PM   #2
Rewards Points: 614
wow .... There will be nothing legal there....
carmon is offline   Reply With Quote
Old 10-07-2012, 08:11 PM   #3
Rewards Points: 12,840
A sure way to make sure there's nothing left to save when that fails and starts spraying out a burning liquid.
One chimmney fire and the whole fire box fills with hot oil that dumps out on the floor.
No insurance company, building dept. fire marshal would ever sign off on this one.
A reguler fire in a fire place can reach 1000 deg. A chimmney fire can be 2000 deg. plus.
A fireplace by far is the least efficient way by far to try and heat any home, and to get this thing to work that would mean you would have to build a fire even is the summer time.
The Following 3 Users Say Thank You to joecaption For This Useful Post:
ben's plumbing (10-08-2012), carmon (10-07-2012), creeper (10-07-2012)
Old 10-07-2012, 09:49 PM   #4
Rewards Points: 614
yep...if you install it like you suggested I would make sure you have the fire departments number handy.... its not safe ...don't take a chance....
The Following 2 Users Say Thank You to carmon For This Useful Post:
ben's plumbing (10-08-2012), creeper (10-07-2012)
Old 10-08-2012, 01:16 PM   #5
An old Tradesmen
Rewards Points: 6,112
As said, using oil is unsafe.
Proleune glycol could be used. It doesnt burn. You alsp neef additional safties for pressre and temp situations.
The Following User Says Thank You to beenthere For This Useful Post:
Old 10-10-2012, 04:48 AM   #6
Rewards Points: 150
Thanks for the opinions. I"m not giving up on this idea just yet, but I do have to think of other families in the future.
Old 10-18-2012, 01:26 AM   #7
Rewards Points: 392
Can't you install a wood stove insert?
zootjeff is offline   Reply With Quote
Old 10-18-2012, 10:54 PM   #8
Rewards Points: 154
vent?
Im not seeing how the chimney would ever vent to start with with an A-coil crammed in the thing.
Patrick Eubanks is offline   Reply With Quote
Old 10-19-2012, 07:05 AM   #9
Rewards Points: 582
don't take this wrong...but give up on the idea..its not worth it no matter how you slice or dice it....ben sr
