Need Power Interrupt Delay, Compressor Reversing - HVAC - DIY Chatroom Home Improvement Forum
Old 07-25-2012, 04:27 PM   #1
Rewards Points: 224
Need power interrupt delay, compressor reversing
I just witnessed my compressor reversing. We had a pretty good power dip to about 50V and was only momentary. I thought to go check the AC immediately and it was very loud. I figured it reversed and shut down immediately. Probably ran for 20sec that way. Afterwards, I went to look at the condensor and both the suction and liquid lines were cool. I waited a few minutes and restarted the system and it runs fine.
Had I not been around, I am sure it either would have blown the fuses, tripped something else out, or blown up. I would like to protect the system from future occurances. No one else in the house would know to shut it down.
viper is offline   Reply With Quote
Old 07-25-2012, 05:16 PM   #2
I don't see how it would have reversed by low voltage. In fact I can't see it reversing rotation by any means if it is a single phase unit.
turnermech is offline   Reply With Quote
Old 07-25-2012, 05:19 PM   #3
biggles's Avatar
keep in mind any unit equalizes after shut down from the hi side into the low side the real problem would of been a restart before it equalizes for an easy restart....
Old 07-25-2012, 08:51 PM   #4
An old Tradesmen
Rewards Points: 6,480
Do you have a digital thermostat with time delay on it? Did the indoor unit stop running?
12V 10A power supply??? zanemason General DIY Discussions 2 02-28-2012 10:57 PM
Power strip hack salex Electrical 3 01-31-2012 07:10 AM
Recurring Power Oddities - Regular Schedule DamienChaos Electrical 16 10-21-2009 08:45 PM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 02:55 PM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 11:23 PM
