Need A Part For Furnace... - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-17-2011, 08:18 AM   #16
Hvac Pro
yuri's Avatar
Rewards Points: 2,276
With all those savings a bottle of Crown Royal whiskey should end up on the sled too.
Old 07-17-2011, 12:54 PM   #17
Rewards Points: 640
its amazing how one part can cost between $32 and $200 depending on who sells it
BlueBSH is offline   Reply With Quote
Old 07-17-2011, 01:18 PM   #18
An old Tradesmen
Rewards Points: 7,372
The second parts store, buys it from a 5th or 6th middle man, and they all make money on it too.
Old 07-17-2011, 01:58 PM   #19
Rewards Points: 640
Yeah, and I bet the original part cost a whole $1 to make
Old 07-17-2011, 02:12 PM   #20
An old Tradesmen
Not even a buck to make. I get York traps for less then, well, you would be fuming if I told you.
Old 07-17-2011, 02:59 PM   #21
Rewards Points: 640
Nah, I wouldn't be mad, I know how the supply chain works, just can't get as close as I would like to be
Old 07-17-2011, 03:19 PM   #22
Hvac Pro
yuri's Avatar
Cozys is a pretty honest and fair bunch. I know how much that trap costs and they did not make that much on it. Maybe thats why they are still in business after many years.
Old 07-18-2011, 05:03 PM   #23
Rewards Points: 640
nothing like having a cap on your ac go bad and have to replace it then find out you are also 2 lbs low on r-22... now that is fixed, can get to the trap, got some pics to see if you guys have any suggestions, will put them up later tonight.
Old 07-18-2011, 06:28 PM   #24
Rewards Points: 640
pics of trap and installation
middle small tube - to pressure switch
farthers back - secondary exchanger drain
closest - condensate hose
Need a part for furnace...-dsc_5712.jpg   Need a part for furnace...-dsc_5713.jpg
Old 07-18-2011, 06:35 PM   #25
Hvac Pro
yuri's Avatar
if you take the long drain route out to the right side you have to be VERY careful not to get a sag in the drain hose from the trap thru the cabinet or it will get waterlogged and not siphon properly. still need an open tee where it exits on the right side. would not glue a solid pipe in. clear hose (at HDepot off the roll) is better plus you can see if it is draining properly. those are VERY finicky furnaces and they changed the setting of the press switch on some as they had lots of nuisance tripping.
Old 07-18-2011, 07:29 PM   #26
Rewards Points: 640
thanks for the info guys, once I get the part I'll double check I am going to do it right before going forward! might be two weeks though, I sware everything goes bad at once, first the AC today, now have a bad brake line on my car leaking fluid....
carrier 58mvp ingnitor part #/ignition problem GEAF HVAC 8 01-02-2011 04:00 PM
2 Part Epoxy Paint Touch Up Tips Hap Painting 4 09-11-2010 05:06 AM
Part Identification tomoni82 Landscaping & Lawn Care 4 07-25-2010 02:36 PM
How to get a level floor out of one that's part concrete and part wood Songbird Flooring 5 01-22-2009 11:24 PM
Briggs and Stratton generator part Jeremy Hillary Boob, PhD Electrical 3 01-10-2009 10:36 AM
