Need A Little Advice/help With Air Unit Questions - HVAC - DIY Chatroom Home Improvement Forum
Old 12-26-2007, 10:18 PM   #1
Need a little advice/help with Air Unit questions
I have a Rheem heat pump unit. We had a power surge a couple of weeks ago and the compressor blew out. I have been told the cost is 1800 or so to fix. I found a couple of compressors online for 740 or 860 and that took alot of looking its not that easy to find. I have someone to install but now the emergency heat has stopped working. I guess my questions are dose anyone know how I can find a compressor for cheaper or are these good prices? And the heating strips that work with the emergency heat are they replaceable? or do these strips work directly with the system when the compressor is fixed or is the heat strickley controlled throuhg the pump?
maybe someone could explain this a little to me
karenmcfly is offline   Reply With Quote
Old 12-27-2007, 10:51 PM   #2
Union HVAC Tech.
First of all no supplier will give a wholesale price to a home owner. Secondly a compressor change out takes @ half a day, involves recovery of freon and evacuation of the system after brazing. All of which requires a Freon certification. No professional is gonna do this for free. Strip heat is independent of the heat pump, the only interconnection is when the system transformner is in the outdoor unit. Rather than shop a compressor price, try and shop for a reliable contractor. You get what you pay for.
bigMikeB is offline   Reply With Quote
New A/C unit won't cool in hot temps wishiknewmore HVAC 39 06-28-2012 08:51 PM
Aluminum-wired house, questions LMH Electrical 2 05-24-2009 03:06 AM
can I swap a (3) 60watt unit into a spot where I have a (1) 60watt unit? joeyboy Electrical 11 07-29-2007 07:25 PM
Used Central Air Unit? shep28 HVAC 2 04-21-2007 07:59 PM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 10:27 PM
