Old 10-31-2009, 03:56 PM   #1
Default Need Input For Venting a Unit Heater
We live within a few miles of Lake Michigan (it's to the west of us), and I'm in the middle of installing a unit heater in a north-west corner. We're going to vent horizontally. Would you suggest venting it on the west side, facing the lake (with the top cap of the vent taking the brunt of the wind.) Or would you suggest to the north, with the side of the vent receiving the brunt of the wind? Or does it matter at all?
Secondly, it's a 115,000BTU Modine heater. I read somewhere that some unit heaters have two gas settings (half and full, I think). I know this is a silly question, but is it possible to retrofit a unit heater so that you have a choice between half and full.
Again, it's probably a silly question.......
Working with black pipe was much easier than I thought. I didn't do much of the work, but I watched . . . and was surprised.
Anyway, thank in advance for the tips.
~j
story is offline   Reply With Quote
Old 10-31-2009, 06:36 PM   #2
Have you checked the local building codes that are applicable to venting a furnace? I know that in california we cannot vent horizontally. We must extend the vent 18 inches above the roof. You don't want the carbon monoxide to seep into the house and kill someone due to improper venting.
thehvacguy is offline   Reply With Quote
More On This Topic
Ice fishing is a popular pastime in the northern states where the lakes and rivers freeze. The ice fishing houses range in sophistication from a little pup tent to a fully built, functioning home. There are several ways to heat the ice fishing house... Read More »
Using your tankless water heater is as easy as turning on your faucet. Whether you have chosen a gas or electric water heater, using them is the same. Once the tankless water heater is properly installed, you simply turn on the hot water. Read More »
When you're trying to save money each month in energy costs, one of the first and best places to make a change is in the hot water system of your home. Homeowners can end up spending hundreds of dollars more per year than they should as a result of an... Read More »
History of Sweet Potatoes
History of Sweet Potatoes by Expert Village
Hi! I'm Jennifer Cail and on behalf of Expert Village, I'm going to show you how to make sweet potatoes. Before we start making our sweet potato casserole, let's talk a little bit about these sweet potatoes. Sweet potatoes are indigenous to the Americas... Read More »
A space heater can save money on gas and electric bills because it heats only a small area and efficiently converts almost all of its energy into heat. However, heaters can pose a serious danger from fire and toxic air pollution. Reduce these risks by... Read More »
How Many BTU's For A Unit Heater For My Garage story HVAC 8 10-27-2009 08:00 PM
Help How to Wire Bathroom "Fan Heater Light Night-light" unit, and questions Tryvidy Electrical 8 04-24-2009 08:40 PM
Dayton 3E837 unit heater manual spolit HVAC 13 01-28-2009 02:50 PM
Help with Heater Unit BenJoeM HVAC 8 11-15-2008 07:16 PM
Adding a hydronic unit heater Joe West HVAC 0 01-31-2007 11:24 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
