Old 09-27-2012, 12:43 PM   #1
Need info how to put the duct work on a FREDRICH FURNACE serial number 612141
I have looked and looked on this computer for info on connecting the duct work on a used fredrich furnace.THe serial number is 612141 and the model number is GDA130NFA. not sure how it goes-did not come with a manual.the cool air is at the bottom of the furnace.plz let me know.thx
deniseebert is offline   Reply With Quote
Old 09-27-2012, 01:12 PM   #2
Bombastic Idiot
notmrjohn's Avatar
I'm confused. Are you sure about model number of FrIedrich furnace? Where is furnace located in house? By cool air at bottom do you mean inlet? Is there return ducting to it? Or is open return? Hot air outlet is on top? Measure inlet and outlet openings. Should be raised lip around outlet, measure outside dimensions. Inlet ducts often go inside opening, measure inside dimensions, you can go outside lip and seal connection real good. Get ducting of same size or union to join to existing ducting and/or plenum. Some plenums are of size to just be connected to outer sides of top of furnace. Seal all joints with metal DUCT, not ducK, tape.
Measure twice, cut once.
Look at the nail, not the hammer. Watch the fence, not the blade.
If you hook your thumb over your belt you won't hit it with the hammer or leave it layin on the saw table.
notmrjohn is offline   Reply With Quote
Old 09-27-2012, 04:53 PM   #3
An old Tradesmen
Moved to HVAC forum.
Properly Sealing HVAC Duct Work craymer45 HVAC 5 11-06-2008 09:47 PM
Duct work patch pvsorge HVAC 9 10-09-2008 12:33 PM
Toughest duct work I can get? napper HVAC 7 07-30-2008 11:52 AM
Tiger Foam On Duct Work atw58 Building & Construction 1 04-25-2008 11:25 PM
Modifying existing duct work Thurgee HVAC 3 04-05-2007 10:35 AM
