Need Info On Air Compressor - HVAC - DIY Chatroom Home Improvement Forum
Old 01-26-2010, 03:18 PM   #1
need info on air compressor
Hi, I hope I'm posting in the right area, as I seen another air compressor post here.
I acquired a used air compressor and need a little info, as the info plate says Doerr (LR22132) and another Sears (pressure dial), etc, and I would like to find the owner's manual if possible. I also need to know if this compressor uses oil, as I don't see a place to put it.
I have pics of the info plates, etc. here:
http://smg.photobucket.com/albums/v7...ir_Compressor/
Is this a home built machine, or from Sears? Thanks much.
donnydoon is offline   Reply With Quote
Old 01-27-2010, 02:21 AM   #2
looks kinda like a place to drain the oil right above where the black wire runs into the motor try googleing air compressor forums id be suprised if there wasnt one, seems like theres one for everything else
kennzz05 is offline   Reply With Quote
Old 01-27-2010, 06:50 AM   #3
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
See if there's a data plate on the compressor itself. The number you gave is for the motor.
wirenut1110 is offline   Reply With Quote
Old 01-30-2010, 03:23 PM   #4
Hi,
Thanks for the responses kennzz05 and wirenut1110. The only other info tag I could find is on the area above the dial:
http://img.photobucket.com/albums/v7...Other_info.jpg
Nothing on the actual tank area itself, but it looks like there's residue from something being on there at one time.
I'll have to look where you said for the oil, I'll wait a couple of days to investigate, when temps should be at least in the somewhat tolerable 30's in my garage, not the brutal windy teens we have this weekend.
Old 02-01-2010, 07:23 AM   #5
It appears to be a drain plug at the bottom right of the silver compressor pump. The horizontal plug is probably the drain plug and the vertical plug is the fill plug. There should be a data plate attached to the pump somewhere.
log_doc_rob is offline   Reply With Quote
Air compressor and framing nailer for DIY ADKstorm Tools 20 11-11-2010 08:38 AM
Bad compressor? lostin60s HVAC 3 08-07-2009 06:24 PM
Compressor Replacement Lawrence Coppar HVAC 1 06-30-2009 11:50 AM
New Compressor - Wrong Charge? shayneb HVAC 4 08-23-2008 09:13 AM
Fridge compressor convert to air compressor? jogr Appliances 1 04-24-2008 02:10 PM
