Need Humidifier ASAP, 2+ Problems - HVAC - Page 3 - DIY Chatroom Home Improvement Forum
Old 02-16-2012, 07:25 PM   #31
Rewards Points: 252
I just installed an aprilaire 800 in a 3000 sq ft house (not including finished basement). It took some tweaking but it works great now. It has to be hooked up to cold water. I also found it to work better by using 120v instead of 240v. Not as much steam comes out of the blower pack when hooked up to 120v but the lower amount of steam disperses better causing less condensation in the area closest to the blower - so I found I got more even dispersion of humidity. The next thing I'm thinking of doing is installing a relay so the fans for the air handlers come on when the humidistat calls for the humidifier to kick on.
mazzonetv is offline   Reply With Quote
Old 02-16-2012, 07:29 PM   #32
Steam humidifiers is not what we were talking about.
Hot water is for media type humidifiers.
hvac5646 is offline   Reply With Quote
Old 02-16-2012, 07:41 PM   #33
Rewards Points: 252
The op mentioned the 800 steam humidifier as an option - not looking to step on toes - just figured I would let the op know that I had good luck with it.
Old 02-17-2012, 08:05 PM   #34
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Thanks! Given the temps in the 50's I may be able to squeeze out a winter and go steam.
I have two "Electric" 40 gallon water heaters in the way, that I can't seem to even give away.
Sent using Android DIY Chatroom
--Chris the DIY Guy
Working on "The Great Wall of Retaining..."
ChrisDIY is offline   Reply With Quote
Old 03-06-2012, 08:05 PM   #35
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Hey BeenThere
Since I have my work cut out for me, maybe I could get a tip as to what is the most critical point to start with sealing? If we are using around 2,000 KwH per month to cool mid summer but are using 4,100 KwH per month to heat, not including propane 2nd stage, is there a specific type of loss I am dealing with? House clearly loses/won't hold in heat faster than it gains.
--Chris the DIY Guy
Old 03-06-2012, 08:43 PM   #36
An old Tradesmen
Rewards Points: 6,906
Windows, wall switches, and receps, door seals.
Band board in the basement, attic access if its in the occupied area. Any holes wires go through into the attic.
Old 03-07-2012, 08:48 PM   #37
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Are those numbers typical for central Indiana? I'm not that knowledgeable but electrical portion (propane accounts for more of cold weather heat) of heating being twice as high as highest cooling?
--Chris the DIY Guy
Armstrong Furnace and Aprilaire humidifier wont shut off! HELP! scott0949 HVAC 8 12-09-2010 06:30 PM
Goodman GMP100-3 Humidifier Issue olds2000 HVAC 1 11-20-2010 10:18 PM
Skuttle humidifier.. Or Sheesh! My Sinuses! Deezil HVAC 3 11-07-2010 06:18 AM
Are you having ice problems? Grumpy Roofing/Siding 27 02-17-2008 03:51 PM
Humidifier & Thermostat BigD HVAC 1 12-19-2007 08:04 PM
