Need Humidifier ASAP, 2+ Problems - HVAC - DIY Chatroom Home Improvement Forum
Old 02-13-2012, 01:13 PM   #1
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Need Humidifier ASAP, 2+ problems
Hello!
Need a humidifier ASAP, but have two maybe three problems. I am using a heat pump, bypass recommends using hot water as a result. Problem 1.
I have tankless water heater, humidifier will not flow at a rate high enough to get hot water Problem 2.
Already have an Aprilaire 8870 thermostat programmed to run humidifier. Problem 3.
Is Aprilaire 800 steam my only option? Any other recommendations?
--Chris
--Chris the DIY Guy
Working on "The Great Wall of Retaining..."
ChrisDIY is offline   Reply With Quote
Old 02-13-2012, 01:31 PM   #2
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
You can run any brand of humidifier on there you want,its basically a pad /a valve /humidistat and some 6" single wall pipe youre installing no matter what the brand name is.
You can buy them at any box store
As far as the plumbing id try it with your cold water supply line and see how it works
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
The Following User Says Thank You to plummen For This Useful Post:
dosy777 (02-13-2012)
Old 02-13-2012, 03:29 PM   #3
Do NOT hook up ANY humidifier to your HOT water.....always use Cold water, Unless its a steam humidifier. Warm water will only promote the growth of things you don't want to be in you duct system. Here is one more sensible aspect to consider.......you have a high efficiency furnace, and now a state of the art humidification system attached to your furnace, if its being supplied by the hot water tank or a hot water line that is fed from your household HWT then every time the humidifier run, so will you hwt, wasting money to heat water for a humidifier. Why is this wasteful?
Its simple, the water being supplied to the humidifier will be passing through the furnace heat exchanger, it will along with the air it is mixed with be heated by the heat exchanger. So using hot water and burning gas to heat that water in the HWT is wasteful and redundant.
dosy777 is offline   Reply With Quote
Old 02-13-2012, 04:07 PM   #4
Originally Posted by dosy777 View Post
Do NOT hook up ANY humidifier to your HOT water.....always use cold.
Aprilaire requires a hot water supply.
hvac5646 is offline   Reply With Quote
Old 02-13-2012, 04:14 PM   #5
You can't get a a bypass humidifier work reliable or at all because the HP dsupply air is not hot enough. Most humidifiers have a design temp of 120*F. A few are even rated at 160*F.
And correct me if I am wrong, but I think as the ODA drops so does the HP supply temp. So that leaves evaporative humidifiers out.
Old 02-13-2012, 06:41 PM   #6
plummen's Avatar
Never had an issue with it before
Old 02-13-2012, 07:26 PM   #7
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Currently
OT: 32F
Supply temp 80F
--Chris the DIY Guy
Old 02-13-2012, 07:43 PM   #8
On back up heat it will work...sure...but how 'bout the guy who uses his heat pump most of the winter?
Old 02-13-2012, 07:44 PM   #9
Originally Posted by ChrisDIY View Post
Currently
OT: 32F
Supply temp 80F
Your gonna need steam bro'.
Old 02-13-2012, 08:40 PM   #10
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Great...
Aprilaire 800 is expensive and this forum is showing mixed results with TruSteam units. I have two heat pumps to make it even worse. I have to figure out a way to use the 850 fan pack and mount centrally.
--Chris the DIY Guy
Old 02-13-2012, 09:26 PM   #11
plummen's Avatar
My goodman heatpump gets me through most of the season around here,especially the way this winter has been so far.
I guess I just havent noticed any problems with my set up
Old 02-14-2012, 05:42 AM   #12
An old Tradesmen
Rewards Points: 6,544
EWC Autoflow S2000 steam humidifier.
Old 02-14-2012, 09:24 AM   #13
we're talking about humidity....
Old 02-14-2012, 11:09 AM   #14
plummen's Avatar
I know,just saying I just run cold water to the humidifier on mine with a heat pump with no noticeable issues
Old 02-14-2012, 11:18 AM   #15
Measure the humidity when it's around 30* or lower and then tell me how good it is.
Running supplemental heat does not count.
Armstrong Furnace and Aprilaire humidifier wont shut off! HELP! scott0949 HVAC 8 12-09-2010 07:30 PM
Goodman GMP100-3 Humidifier Issue olds2000 HVAC 1 11-20-2010 11:18 PM
Skuttle humidifier.. Or Sheesh! My Sinuses! Deezil HVAC 3 11-07-2010 07:18 AM
Are you having ice problems? Grumpy Roofing/Siding 27 02-17-2008 04:51 PM
Humidifier & Thermostat BigD HVAC 1 12-19-2007 09:04 PM
